Lands Phones Logo
Anonymous Posted on Aug 26, 2013
I just purchased an aastra 9116lp and have no display
Jas Geer
Level 1:
Passionate:
Visited the website for 10 consecutive days.
Habit-Forming:
Welcome Back:
Visited the website for 2 consecutive days.
  • Contributor 1 Answer
  • Posted on Nov 24, 2021
Jas Geer
Contributor
Level 1:
Passionate:
Habit-Forming:
Welcome Back:
Answers
Questions
0
Helped
256
Points
No it's an AC output adapter. 16 Volts AC. I thought it would be DC also but after looking at the output on the plug it showed AC. I measured the voltage and got 19 Volts AC. However I still can't get my display to work so I'm tearing the phone apart now to see.
Ian ruth
Level 1:
New Friend:
  • Contributor 32 Answers
  • Posted on Nov 06, 2013
Ian ruth
Contributor
Level 1:
New Friend:
Answers
32
Questions
6
Helped
9220
Points
38
A 9116 N has a power brick that needs tone plugged in to it. They are usually a black power brick. Without the brick there is no display If you are referring to no caller I'd. That is a function that you have to ask for from your provider. A blank screen usuall has a funny weak ring also. If you have a grey power supply look at the voltage on the brick if it say that there is ACvoltage output. It is not the correct one. You need to have a DC voltage output on that type of phone
Fix display lines justification on Aastra M5316? It’s so left justified that first bit of info is cut off.
To adjust the display lines justification on an Aastra M5316 phone, you can follow these steps:
  1. Press the "Menu" key on the phone.
  2. Use the arrow keys to scroll to the "Contrast" option and press the "Select" key.
  3. Use the arrow keys to adjust the contrast of the display until the lines are fully visible.
  4. Press the "Next" key to scroll to the "Line Justify" option and press the "Select" key.
  5. Use the arrow keys to adjust the line justification until the lines are properly centered on the display.
  6. Press the "Save" key to save your changes and exit the menu.
If you continue to have issues with the display lines justification on your Aastra M5316 phone, you may want to try resetting the phone to its default settings. To do this, press the "Options" key on the phone, then scroll to "Reset Phone" and press the "Select" key. Confirm that you want to reset the phone and it should revert to its default settings, including the default display line justification.
If the issue persists after resetting the phone, it may be a hardware issue and you may need to contact Aastra customer support or a qualified technician for further assistance.
Aastra 9116LP voicemail password
i don't know. check this link.
https://www.manualslib.com/manual/205091/Aastra-9116lp.html
if more required, please take your photo a ID and phone to
a local retailer for this phone near your location.
How do I make a conference call using the Astra 9116lp phone?
Your provider will have to set it up for u it usually is very expensive. But google conference call and you can find a 3rd party conference company that can usually give a far better rate than your provider hope that helps
I am only using line 1 on the aastra 9120, how do i get "check line cord line 2" off the display?
i have the same issue. considering the following solution; install a splitter to connect both phone ports to a single line.
12helpful
2answers
Need to adjust date and time on screen.
Just above the Hold button, with the Aastra name display, that is a sliding piece that will uncover your setup menu button. Press that and navigate to time/date settings.
Hope this was helpfull.
Top Aastra Telecom Lands Phones Experts
k24674
Are you an Aastra Telecom Lands Phone Expert? Answer questions, earn points and help others
