Freezers Logo
Posted on Apr 10, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Food thawing in freezer
It's a kenmore 14 upright frostless freezer model # 253.9244410 the light works, the fan runs, the compressor kicks in. neither line from the compressor is cold. needs a charge? it's 11 / 12 freon
Dan Webster
Level 3:
  • Master 8,221 Answers
  • Posted on Apr 11, 2009
Dan Webster
Master
Level 3:
Answers
8221
Questions
5
Helped
2379054
Points
25840
You may have a small leak in the evaporator. You could try to get a replacement freon with stop leak from the automotive store and give it a shot. If it is a R12 unit then it is too old to repair. But it is worth the gamble to shoot it with freeze 12 or an equivilent before you condemn it.
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Temperature alarm light is on. Food is starting to thaw. What's wrong.
freezer isn't working; do you hear the compressor kick on? No? then it has to be serviced
Kenmore upright freezer
order a new seal at the link I provided or ebay or your choice
also check the lid or door adjustmens and obtain specific help instructions at the link I provided
Appliance Repair Help Troubleshooting and Appliance Parts
I have a Kenmore upright freezer model# 253.9260210. We noticed that our food was starting to thaw. I opened up the coil area and noticed a small piece of ice on the coils. I melted the ice and turned...
Feel top of the compressor and tell me how hot after it has been running awhile. I need also that you advance the defrost timer=>. 216517400 Defrost Timer
clockwise slowly untill the compressor stops or starts. I need to make sure the timer is not stuck into defrost. I want you to leave the compressor off for up to 35 minutes. If the freezer compressor doesn't restart bt then simply again turn the timer clockwise slowly until it does and then stop turning. The defrost timer is location 23 in this photo HERE If you need to turn the defrost timer like this to restart the compressor then replace the defrost timer and this will resolve the freezing problem. If not we move to the defrost heater location 14 in the sme photo=> 216254600 Defrost Heater
I am going to stop here until I hear from you, Thanks Sea Breeze
I have a Frigidaire freezer LFFU1424DW not freezing. Came home to melting ice and thawed food. I heard clicking noise like a fan but goes off after a few seconds. Help please.
first of all unplug that freezer and wait for 15 mins. move it five feet from the wall. after 15mins, plug it back and kick in compressor at the same time!!!! remember plug and kick at the same time. the ckicking noise come from the starting relais. this says that the compressor has a problem. If it doesn't work ; you will have to call a service person who will replace the compressor for you.
1helpful
My Kenmore up right freezer is not working properly. The fan in running however the condensor will come on for a few seconds and then turn off. The food is thawing out in the freezer and water is dripping...
When you say condensor you probably mean compressor. If the big metal motor at the back is making that noise that is your compressor. The compressor is either bad or the relay for the compressor is bad. I recommand replacing the relay first since it is your cheapest solution and then if that doesn't solve it then you can decide if you want to replace the compressor or not as this is not something you can do yourself and can be quite costly to do if you have a technician do it. Hope this helps.
James Memije
Head Technician
Accufix Appliance Service Centre
11helpful
2answers
My kenmore frostless 16 upright freezer alarms
kenmore elite, alarm kept going on and b flashed on and off. I finaly figured out on bottom of freezer there is a battery door open it and change 9v. thats it,
3helpful
Food in freezer is thawing, compressor very hot to the touch
It sounds like the motor to the circulating fan is wearing out . This fan is hard to diagnose as it will spin the blade , but as you said it will not spin fast enough to circulate air thru the freezer and refrigerator. The motor is DC non brush type. It will cost a minimum of $300.00 to repair/replace this fan assembly, but it is worth that compared to replacing the refrigerator
3answers
Kenmore Upright Freezer Alarm
I think problem its not with thetmostat but the compresor work but not correctly not have enought power to create pressure.
3helpful
Access to the circulation fan Kenmore upright freezer
There is a panel on the lower back wall inside the freezer.
Remove it to access the fan motor.
Temp alarm on freezer alarming.
that's the same problem i incurred, i replaced the thermostat and the fan. seems to be working fine.
Top Freezers Experts
ADMIN Eric
ADMIN Eric
ADMIN Andrew
ADMIN Andrew
Are you a Freezer Expert? Answer questions, earn points and help others
