Cell Phones Logo
A
Anonymous Posted on Oct 20, 2017
Outgoing calls Problem
I have an Android Samsung Galaxy S3 run 4.1.2 Jelly Bean. Whenever I try to make an outgoing call on my cell phone, it brings up skype to make a call. I never want to make outgoing calls with skype. How do I turn this off and set it back to using my cell carrier to make the call? If anyone know the solution of this issue please let me know.
monetfoot wear
Level 2:
New Friend:
  • Expert 61 Answers
  • Posted on Oct 20, 2017
monetfoot wear
Expert
Level 2:
New Friend:
Answers
61
Questions
Helped
10422
Points
394
Transfer SIM to another working device to check if outgoing calls will work. If problem still persists, please contact us via hotline or visit the nearest Smart Store. If you cannot make outgoing calls while roaming abroad, click here by Camera Mobiles Camera Mobiles Tablets
1 Related Answer
Anonymous
  • 7 Answers
  • Posted on Feb 22, 2013
SOURCE: my camera on my galaxy s3 doesn't work
have you unlocked or rooted your phone? try reflashing your phone, if you dont know how search it on google, i recommend going to highonandroid.com and follow the steps in rooting your system to reflash the software. Remember to back up your memory incase something goes wrong
Touch screen don't work
Sounds like you\'re another victim of the update from Android Jelly Bean to Kit Kat, the new OS is very buggy and can cause screen lock, battery drain and a host of other weird problems. Go to Settings, More, About Device, if Android Version says 4.3, Kit Kat is the problem. If you do NOT use ATT, you can try this link to downgrade back to Jelly Bean. If you\'re with ATT, you can either read the next paragraph, or wait for the eventual fix and just suck it up for now.
http://www.androidpit.com/how-to-downgrade-galaxy-s3
Another option if you\'re an ATT customer or are little more adventurous is to abandon Samsung\'s version of Android (Linux) and move to CyanogenMod11. I\'ve used each version of CM since 6 and been very happy. CyanogenMod11 is just another type of Android (Linux) and will work on the Galaxy S3/S4. It\'s pretty easy to install, just go to http://www.cyanogenmod.org/ and click on the green button.
There\'s a loader you must install in Windows and a few settings to switch on the phone to allow it to install, but otherwise, it\'s pretty painless. Your phones desktop will look a little different and your phone will need to reinstall all your apps (you\'ll start all games over), but it happens automatically and all you contacts are already backed up on the Google servers.
Factory reset
Is there any particular reason to format the tablet?
Will note n7000 get further android os updates
The only way to get 4.2.2 is this:
The first generation of the Galaxy Note line, N7000 initially runs Android 2.3.5 Gingerbread and later features Android 4.1 Jelly Bean. Owners of the device can update their Galaxy Note N7000 to Android 4.2.2 Jelly Bean with special features such as colour inversion, notification drawer, lock screen shortcuts and custom Quick Settings.
Using Slim Bean ROM, your Galaxy Note N7000 will run the latest Android 4.2.2 Jelly Bean containing all features of the Android OS, customisation and tweaking capabilities, amazing themes, stability, constant update and relatively bloat-ware free system.
Warning: Slim Bean ROM is a customised ROM and its developers are not liable for any damages on your device. The featured ROM only applies to Samsung Galaxy Note N7000 and should never be installed to any other devices. Read and follow the instructions carefully to prevent damaging your handset. Do this at your own risk.
Requirements:
Before you perform the installation, make sure that your device has met all prerequisites.
  • Your device must be rooted to be able to flash the custom ROM. Click one of the OS version for rooting instructions: Gingerbread 2.3.5 or Jelly Bean 4.1.2.
  • Create a backup of all your personal information, settings and data files on your device. Do not use Samsung Kies since Slim Bean ROM is a custom ROM which won't be detected by the program.
  • Uninstall all antivirus apps on your handset and temporarily disable any security programs on your computer. It may interfere the installation progress.
  • Make sure that the battery level is at least 50 per cent to prevent any power interruption during the installation.
  • Enable USB debugging mode on your device.
  • Install a custom recovery app such as ClockWorkMod recovery or TWRP.
  • Install USB drivers on your computer for the Galaxy Note N7000.
  • Download the Slim Bean Build 6 Android 4.2.2 ROM and the Slim Google Apps package on your computer.
Flashing Instructions
1. Connect your Samsung Galaxy Note N7000 to the computer via USB cable.
2. Copy the Slim Bean custom ROM and Slim Google Apps package to the external memory of your device. Do not extract any of them.
3. Disconnect your device from the computer then reboot it into Recovery mode using the custom recovery app.
4. Inside the Recovery mode, select "backup and restore > backup" to create a nAndroid backup of the current ROM which you can restore later in case of any problems.
5. After the backup, select "wipe data/factory reset" and "wipe cache partition" to clear all data on your device.
6. Then select "install zip from SD card > choose zip from SD card" and choose the Slim Bean ROM zip file to install it. Do the same with the Slim Google Apps zip file.
7. Once the installation is complete, go back then select "reboot system now." Boot up may take 5 minutes for its first run.
Congratulations! Your Samsung Galaxy Note N7000 is running Android 4.2.2 Jelly Bean using Slim Bean ROM with tons of other features not found on a regular stock ROM.
For any issues during the installation, send your feedbacks to the
1helpful
My camera on my galaxy s3 doesn't work
Feb 22, 2013 • Cell Phones
After i installed the internet software, my phone started shutting down by itself what shall i do?
if you are having a android mobile , than dude, try android recovery mode , shutdown your cell, take out bttry for 5sec , put it back, then press powerkey ,vol. up key, and home key all at the same time , then , the phone will boot through android recovery console , search the option 'restore factory settings' then , reboot your cell, 95percent problems solved by this method in android .
2answers
YoYo the spammer of all Samsung questions is back!!!
The Samsung Smooth is a CDMA phone since it is offered through Verizon. It is possible to unlock this phone, but very difficult and requires advanced unlock software.
Top Samsung Cell Phones Experts
Mike Cairns
Mike Cairns
ZJ Limited
ZJ Limited
Are you a Samsung Cell Phone Expert? Answer questions, earn points and help others
