HP Officejet Pro L7680 All-In-One Printer Logo
A
Anonymous Posted on Aug 26, 2013
HP 6700 Officejet Premium: When printer was turned it displayed a blue screen with the error code 0005FBB6. I've tried all of the trouble shooting procedures to no avail. I have contacted HP and they are sending a new printer, however, I want to get my ink cartridges out but the carriage is locked in the far right position and will not move. How can I get to ink cartridges?
5 Related Answers
Anonymous
  • Posted on Jun 28, 2009
SOURCE: cartridge error, refer to device documentation for troubleshoot
show me a massage Cartridge error, refer to device documentation for troubleshoot printer model hp officejet 5610 all -in- one what is the problem and how do i solve thnk you
Anonymous
  • 14 Answers
  • Posted on Oct 29, 2009
SOURCE: carriage jam on the right side
Here is your Solutions
aahhhh8
[email protected]
  • 32 Answers
  • Posted on Nov 19, 2009
SOURCE: HP PSC 2210 printer carriage
Part #'s are
ASSY-LATCH BLACK - C6490-60011
ASSY-LATCH COLOR - C6490-60012
Parts re-sellers for HP:
United States Big Blue Products, Inc.
Huntington Station, NY
Tel: 888-BIGBLUE
http://www.bigblueonline.com/hp.htm
Bradshaw Group, Inc.
Richardson, TX
Tel: 972-644-7558
http://www.bradshawgroup.com
Computer Exchange LTD
Lawrenceville, GA
Tel: 770-806-3939
800-883-0800
http://www.computerexchangeltd.com
Depot America, Inc.
Farmingdale, NJ
Tel: 800-648-6833 or 732-919-0209
http://www.depot-america.com/
Image1 Products, Inc.
Plano, TX 75074
Tel: 866-846-2431
http://www.image1products.com
Laser Pros International
Rhinelander, WI
Tel: 888-558-5277 or 715-369-5995
http://www.LaserPros.com
Masterworks International Inc.
Houston, TX
Tel: 800-695-2282
Fax: 713-896-0885
[email protected]
http://www.mwintl.com
Parts Now!
Middleton, WI
Tel: 1-800-886-6688 or 608-276-8688
http://www.partsnow.com
System Design Advantage LLC
Bloomington, MN
Tel: 1-800-947-0007
http://www.sdallc.com
TSAworld, Inc.
Norcross, GA
Tel: 800-633-6626 or 770-417-2323
http://www.tsaworld.com
Vance Baldwin Electronics
Fort Lauderdale, FL
Tel: 954-723-9191
http://www.vancebaldwin.com
Anonymous
  • 159 Answers
  • Posted on Mar 15, 2010
SOURCE: Ink Failure on HP photosmart premium C309g printer
Turn off the machine, unplug the power cord from the back of the machine, remove the ink cartridges (lift the lid up at the base of the control panel), wait 2 min, plug the power cord back in, press the on button, wait until the printer prompts that the ink cartridges are missing, then replace the ink cartridges. If this doesn't fix the problem you may have to re-prime the ink lines to clear the error. You can find instructions for this at http://www.ccl-la.com/blog/index.php/hp-photosmart-ink-system-failure-1/.
Anonymous
  • Posted on Oct 07, 2010
SOURCE: Printer reads out "Print Cartridge problem (Tri Color)
I discovered on mine, exact same problem, I opened the tray, removed the cartridge, and forced it back in hard and fast. It didn't work the first 12 times but after that, it got a solid connection and it worked. Works fine now. Anyway that's the problem and the problem isn't the cartridge (genuine hp cart here). The problem is on the printer side, the pins that hit the cartridge. Anyway get rough with it, slam it in and out, close the tray, if it doesn't work within 5 seconds, open the tray and do it again. It WILL work.
PRINTER IS NOT SCANNING AND COPYING FILES BUT PRINTING FROM COMPUTER
https://support.hp.com/us-en/product/hp-officejet-6700-premium-e-all-in-one-printer-series-h711/4322971 copy and paste this address into your browser's address window and press enter, Select troubleshooting in that screen
2answers
How to up date hp Officejet 6700 Primium all-in-one code auf8437ojde38
  1. Switch on the HP Officejet 6700 series printer and wait until the printer is READY. [The Power light should be on]
  2. Double click on OJ6700_R1435A.exe to launch the HP Printer Update utility. A list of OfficeJet 6700 Premium series printers detected will be displayed on the screen.
    Note: If the Wired network printer you wish to upgrade is not displayed in the detected printer list, click on the Refresh button to scan for printers connected via the wired network.
  3. Click on the checkboxes on the left to select single or multiple OfficeJet 6700 series printers you wish to upgrade.
  4. Click on the Update button to start the firmware flashing process.
  5. Message showing "The selected printer has been updated successfully" will be displayed. Firmware flashing will begin.
    CAUTION! Do not interrupt the printer during the upgrade process. Printer may be damaged if power is interrupted during the firmware upgrade process.
  6. When the printer has successfully completed the flashing process, it will automatically print out a Self Test Diagnostic Page, that will show the new firmware version.
  7. Click on the Done button to close the HP Printer Update utility.
HP Officejet 6700 Premium All in One Firmware
What is an HP Officejet 6700 printer error code 20?
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
7helpful
HP 6700 printer change ink cartridge
http://images10.newegg.com/User-Manual/User_Manual_28-415-214.pdf
Open ink access door.
1. Make sure the printer is turned on. Never turn off the printer when ink cartridges are missing.
2. Open the ink cartridge access door. [This is the panel that is to the left of the touchscreen. To open, put your fingers on the upper left hand side of the panel (by the logo: HP OfficeJet 6700 Premium), You should be able to gently pull the panel so that it opens out.]
NOTE: Wait until the print carriage stops moving before proceeding.
3. Press the front of the ink cartridge to release it, and then remove it from the slot.
4. Remove the new ink cartridge from its packaging.
5. Using the color-coded letters for help, slide the ink cartridge into the empty slot until it is securely installed in the slot.
Replace the
26helpful
4answers
Error code 0005FBB6
  1. Turn on the HP All-in-One.
  2. Disconnect the power cord from the back of the unit.
  3. Press and hold the # and 3 buttons simultaneously.
  4. While still holding down the # and 3 buttons, connect the power cord to the back of the unit.
  5. Continue holding the buttons until the Power button blinks.
  6. Follow the instructions that display on the unit to select the language settings.
Then when that's done, try printing, or copying items. If its still not working, check the ink and change those out and this should fix it.
Cloud Striver
If you have further questions email [email protected]
k24674
Grand Canyon Tech
Grand Canyon Tech
