I need to remove the piston from a homelite mightylite strimmer,I need info on how to get the piston out.I can strip it down so far but don't know how to remove the piston arm assembly.Any info would be appreciated or better still a parts assembly diagram.............
Thanks for reply, I don't need a replacement part , the problem i have is that for some reason the piston arm was put in the wrong way. So it does not clear the side of the barrel and needs to be turned so the curve of the arm clears the barrel as there is a groove which allows clearance.It looks like it has been stripped down b4 and reassembled as there where other parts that had been put back wrong which i have allready remedied.
