Frigidaire 20 cu. ft. / 566 liter Upright Freezer FFU20FC4A Logo
A
Anonymous Posted on Aug 25, 2013
The defrost drain tube must be plugged be cause the water covers the floor of the freezer and also inside the door
5 Related Answers
Anonymous
  • 1314 Answers
  • Posted on Sep 11, 2008
SOURCE: My freezer's defrost systems runs constantly
i dont think so i would look at the compressor kicking out on thermal overload or a faulty thermostat thermostats have two settings cut in cut out your cut in could be bad and not turning the compressor on till the temp reaches melting temps now if your hearing a click buzz then you need to look at the compressor and make sure the compressor fan is running but its not a defrost promblem
docjohn174
john gagnon
  • 943 Answers
  • Posted on Sep 27, 2008
SOURCE: Water does not drain from the Freezer during the defrost cycle
hi thanks for the question the drain hose goes to the underneath by the compressor thaw out the freezer and clean the drain hose this will solve the problem thanks the appliance doc
Anonymous
  • 311 Answers
  • Posted on Nov 28, 2008
SOURCE: Freezer not Freezing
If unit is running then it is not worth fixing. I cannot see your repyl due to some tech issue w/ the site, so it may be a day or so before I can reply again. Please leave feedback for me if appropriate. Thanks
jvernice
Joseph Vernice
  • 63 Answers
  • Posted on Jul 29, 2009
SOURCE: I have a sears upright
Make sure that the fridge is level. If the drain pitch is not sufficient, this will happen. The solution is cheap too!
Anonymous
  • 109 Answers
  • Posted on Aug 23, 2009
SOURCE: Freezer forming Ice on the bottom not draining water
pour some hot water in the drain if this does not work use compressed air
Testimonial: "So far that worked great, we will see if it continues to drain when the freezer is back on and does it defrost cycle."
Frigidaire FFHS2311LWD has water pooling up and freezing bottom drawer and lower vent. Drain tube doesn't seem to be clogged. Water leaks onto floor some days.
the drain tube is most likely clogged. if the lower vent is freezing up there is no way to confirm because it is covered with ice. the reason water leaks onto the floor is, the refrigerator goes into defrost, frost melts and runs down the ice to the door. use a hair dryer to remove all ice, then use hot water to check drain. drain tube may be up to a foot long and may have a trap. you may have to go in through the back to gain access to the drain
Kenmore refrigerator with a bottom freezer leaks water on floor
Hello Wayne,
You already mentioned the reason for the excess water. When the freezer automatically defrosts itself once every 24 hours the melted water drains down through a tube down to a water pan at the bottom of the refrigerator where it sits and supposedly evaporated by the fan back into the atmosphere. However in your case the excessive dust is preventing the evaporation phase to occur by the fan. You need to vacuum as much of the dust as possible and your problem will disappear.
Good Luck
Rich Lilja
MY FREEZE WILL NOT GET COLD OR FREEZE ANYTHING
Check the temperature setting
Assure that there is enough room for air flow in the freezer or freezer
Check for air flow restrictions in vents
Test the temperature control
Clean the condensor coils
Check the door seals
Test the door switch
Test defrost heater
Test defrost timer
Test evaporator fan
Check for a clogged drain tube
Check for refrigerant leak
Freezer is too cold
Freezer is noisy
Hissing and popping is normal, it is the defrost heater.
Check that the freezer is level
Check the drain pan
Check the condensor fan
Check the evaporator fan
Inspect the compressor mounts
Freezer runs continuously
Defrost the freezer
Freezer starts and stops frequently
Check the outlet voltage
Test the condensor fan
Test the compressor relay
Test the overload protector
Test the compressor motor
Freezer does not defrost automatically
Test the defrost timer
Test the defrost heater
Test the defrost thermostat
Freezer has an unpleasant odor
Remove spoiled food
Clean freezer interior with a solution of h
Clean freezer interior with a solution of hot water and baking soda
Clean the door seals
Remove breaker strips and check for wet insulation
Water on floor outside of freezer
Check the drain pan
If you have an ice-maker, check the water supply hose going into and coming out of the water inlet valve
Water inside the freezer
If you have an ice-maker, check freezer and ice-maker for level.
With all this it helps to solve the problem....
1helpful
FREEZER MAKING ICE, BUT FOOD IS THAWING
If you have a Freezer on the top model Kenmore, with warm temps in the fridge, AND water dripping onto the top shelf of the lower fresh food compartment (FFC), this is usually caused by a clogged defrost drain. Since Kenmore is not an actual manufacturer of anything, they take other brands, i.e. Kitchenaid, GE, Frigidaire, etc., take their names off and put on a shiny Kenmore nametag. This is a common problem with Kitchenaid refrigerators. You can determine if your Kenmore is made by kitchenaid by looking at the model # tag. the first three digits will indicate the manufacturer, Kitchenaids begin with the sequence, 106.*.If this is indeed how your model # begins, keep reading. Since the water cant go down the drain tubing to the pan at the bottom of the unit, it builds up on the freezer floor, eventually blocking the air return vents from the fridge to the freezer, and the vent from the freezer to the fridge. YOu can check this very easily. Look at the ceiling of your FFC, near the back. toward the sides you will see two square holes, about 2" square, stick your finger and feel around the inside of those holes, do you feel any ice/frost, or do you just feel styrofoam, you might even see frost/ice below the level of your ceiling? This drain usually gets clogged with defrost water that does not completely drain, then of course it freezes, eventually plugging up the drian hole located at the level of your freezer floor, behind the back wall. The water keeps accumulating, and freezing, on the freezer floor, eventually filling in and clogging the air vents..no air flow , the fridge wont cool. The easiest way to resolve this, empty out all contents and store someplace cold for 24 hours...a 2nd fridge, outside in a cooler if its cold like here in chicago. After its empty, unplug, open both doors and blow a fan for 24 hours. Prepare for an abundance of water due to melting ice.
After you defrost, you can plug it back in and it will be fine, HOWEVER, I suggest you take the back freezer wall off, you might have to take a floor cover off first, likely 2-4 screws in both the floor and the back wall. When you have the evaporator exposed, you will see a black cal rod defrost heater underneath the evaporator, as well as your drain hole just to the right of center underneath both heater and evaporator. Take a piece of 12-14 gauge solid, not stranded wire, removing the insulation and exposing the entire 6-8" piece of copper wire. wrap the wire around the diameter of the cal rod heater, 3-4 turns should be sufficient, and stick the other end of the wire down that drain hole. This will melt any ice that will build up in the future, everytime your unit goes into defrost cycle, so this wont happen again.
If air vents are clear of frost/ice, next thing to check is the back wall of your freezer, does there appear to be frost/ice/snow on the back wall? If so, your unit is not defrosting. On most Kenmores, this is usually caused by your defrost timer, located in the canopy mounted at the top of the FFC on Top freezer models, or your defrost thermostat, which is clipped onto the evaporator coil inside your freezer. Again, if its a 106 model Kenmore, this thermostat will have a pink and a brown wire coming into/out of it. My suggestion, if it isnt defrosting, change both. tjhe defrost control will connect with a plug, but you will have to hard wire the thermostat, ( cut wires from old, strip wire, and connect using wire nuts and electrical tape.)
Since y ou mentioned the water accumulation, more water recently, my diagnosis would be the former versus the latter, as the lack of actual defrosting coincides with lack of defrost water, however I'll never say never.
If your unit is a side by side model, check for ice on freezer floor...clogged drain. Check again for frost/ice on back wall, not defrosting, check same two parts, (the heaters rarely go bad on Kitchenaids, but never say never) You should also check for air flow into fridge, even if no frost / ice visible on back wall. Open the FFC door, and locate the air vent near the top, back of the fridge, on the left wall. While depressing the door switch, AND WITH THE FREEZER door closed, put your finger/hand near that vent. Do you feel any cold air? If you dont, you could have a bad door damper, not uncommon, or a bad damper control--> the temperature control WITHOUT the off or "0" position.
If any of this seems a bit overwhelming, I suggest you have a reputable repair technician check your fridge.
Oh, and lastly, you WILL NOT have two compressors, one for each compartment, nor will you have two sets of defrost heating elements, one for each half.
ALL cooling for 99% of refrigerators made in last 25 years takes place in the freezer, with the fridge being an empty box, except for an air intake vent, and an air exhaust vent which leads directly back into the freezer. When a refrigerator unit seems to still be cold in the freezer, but not cold enough or not cold at all in the FFC, its ALWAYS going to be caused by lack of air flow. But as you can see, there are a few things that can cause that lack of air flow.
Our frigide is defrosting water into the bottom the fridide the lays in the cavity under the crisper and after a while(8 or 12 DAYS)RUNS OUT ON THE FLOOR
you have a clogged defrost drain. when y our unit goes into defrost, the water that is supposed to go down a tube from your freezer down to the bottom outside of the unit, into a pan to evaporate, instead is going into your fridge etc. This drain needs to be cleared. I would not recommend doing it yourself, you may cause further more expensive damage.
Refrigerator FAQ and Tips
1helpful
I have 16.7 upright Frigidaire Ultrafreeze freezer, Model AFFU1766DW3 & SERIAL #WB51720061, manufactured 04/05 that I purchased new 11/05. Water was on the floor next the the freezer but the light on...
Your evaporator coils frost up in normal use and every eight hours or so the entire unit shuts down and the defrost heater comes on to melt the frost. This cycle last about 20 minutes. The melted frost drips into a drain pan and through a drain tube to the drain tray under the freezer/refrigerator where it's evaporated by the condenser fan.
Your drain tube may be stopped up with ice at the upper end because it drains too slow because it's stopped up at the lower end in the evaporator pan under the unit at the floor. It can get dust and mold in it. Once you get the ice out at the top a little pressure with a turkey baster will usually clear it out. Flushing it out with hot water and clorox may help.
Make sure it drains quick enough to prevent refreezing. . The drain should be located below the evaporator coils on the lower back of the freezer.
4helpful
Water leaking onto the floor from freezer drain...
Sep 20, 2009 • Freezers
Our upright freezer drips water on the floor. We believe the seal is bad since ice also forms inside at the top of the door. Is the seal replaceable or should we buy a new unit?
Self-defrosting refrigerators/freezers dispose of the water generated during the defrost cycle, usually via a tube or channel that directs the water to a pan at the bottom of the refrigerator. From the pan, the water normally evaporates.
If the tube or channel is clogged or obstructed, the water backs up and leaks into the inside of the refrigerator/freezer compartment. Then the water builds up at the bottom, inside of the refrigerator. When the water has built up for a time it may spill out of the front of the door opening. To fix this problem, clear the drain tube or channel and allow the defrost water to flow down to the drain pan.
Aug 16, 2009 • Freezers
2answers
Water in the floor
there is a drain hose that comes out of the bottom of the cabinet into a drain pan underneath your freezer take a look and see if that got pulled loose during your move. if it is in place then you most likely have a plugged drain. this can be cleaned fromt he inside at the botom. reomve the bottom basket and the shelf right above it. you will see ice build up on the floor of the freezer and and behind the cover. just defrost the ice you will uncover the drain hole flush warm water thru the line till it runs clear. good luck peyton
2helpful
Freezer "leaking" cold water on floor
sounds like a drain clog in the freezer compartment above. remove the freezer rear panel and totally defrost the evaporator area, directly under the evap you see( under all taht ice) a small drain hole that has become frozen over, try defrosting with either a hair dryer( not a heat gun too much heat youl melt everything) or by pouring hot water donw the drain until you get a free flow of water down the tube. after its clear reassemble and you should be fine
Top Frigidaire Freezers Experts
ZJ Limited
ZJ Limited
Are you a Frigidaire Freezer Expert? Answer questions, earn points and help others
