Click on the frame of the chart, then hover over the frame of the chart. If the cursor is hovered at the corners or centre of each of the sides, the pointer changes into a two way arrow, click and drag at this point to resize. To move the chart, hover over the frame of the chart at any other point and and the cursor changes into a 4-way arrow, click and drag to move the chart to your desired posi.tion
SOURCE: How do I widen Data Labels in MS Powerpoint Pie Charts?
You wouldn't be able to resize the Data Labels. The only thing you can do is either resize the Chart Area so that things will space out accordingly or right-click and format the Data Labels and make the font smaller.
SOURCE: unable to create chart in excel
Check the source data that it is using to create your chart (right-click choose SOURCE DATA). The result you're getting sounds as if it may not include all the data you want to chart. Generally should include at least two rows AND at least two columns.
SOURCE: ABOUT MSchart pie code
This link will provide you a sample Pie Chart code using Visual Basic:
http://www.chestysoft.com/xgraph/demopie.asp
