Princeton Digital VL1717 LCD Monitor Logo
Posted on Sep 10, 2017
The monitor goes black. when I press the on off it comes back on.
I have a Princeton VL1717. The monitor goes black. When I press the on off repeatedly it comes on then turns off again. The intervals are varied form a few minutes to an hour or more. Is it the switch? I have a differnet model princeton that was going off and on. But I changed 3 capictors as recommended on this forum and it works fine now. Could this be a simalr issue?
  • Anonymous May 11, 2010
    m_zuk, Could be. Did you do the flashlight test? Just what do you see AFTER the panel goes to a black screen? Could also be intermittant(thermal) solder joints on the botttom of the SMPS/INVERTER board(s). Do these Princeton monitors have 2 or 3 boards? 2 boards mean you have a COMBO. 3 boards then SMPS and Inverter are separate. You did not state the age of these monitors. Were these units causing problems last month, or six months ago? When did you see a nice a "crisp,sharp,bright" screen last? Have you contacted Princeton to see if they have a REBUILT swapout program? You send them yours + $40 - $90.. They send you same model in return. I'm louie12fix on fixya or lmistyrel @aol.com. bye for now.
4 Related Answers
Anonymous
  • 79 Answers
  • Posted on Aug 08, 2009
SOURCE: the monitor shuts off. Turning the power off
the monitor is going into power saving mode ... it can happen if it is not receiving any signal from the pc ( pc is not running or booted properly, bad video cable connection monitor to pc) or the pc is itself in suspend/standby mode.
Anonymous
  • Posted on Aug 19, 2009
SOURCE: princeton vl1918 flashes on than off
See previous solution for Princton Monitor cycling on and off.
Solution: Change out 3 capacitors.
budmrtn
Bud Martin
  • 11361 Answers
  • Posted on Sep 11, 2010
SOURCE: princeton vl1717 monitor say signal
Please read here:
http://www.fixya.com/support/r4873371-fixing_out_range_format_not_supported
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
Failed TV and Monitors: http://s807.photobucket.com/home/budm/allalbums
http://en.wikipedia.org/wiki/Capacitor_plague
budmrtn
Bud Martin
  • 11361 Answers
  • Posted on Oct 05, 2010
SOURCE: What's sync rate of Princeton
You should set it to the native resolution of this monitor which is 1280 x 1024 @60Hz.
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
1helpful
Very faded. hard to read the screen
Try the monitor on another PC. If it is the same way, the TFT Matrix screen itself is Failing; You will have to replace the screen. TCC
THE BRIGHTNESS OF THE MOITOR IS DARK CAN NOT SEE HOW TO BRIGHTEN WITH CONTROLLS
More likely to have power supply like the failed PRINCETON as shown in my albums.
Basic LCD monitor troubleshooting guide:
Please post back what you find.
Nothing on screen, black, when on
If you are going to DIY and have proper tools and know safety precaution then please read on:
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply (they should be replaced in a set), blown fuses; poor solder joints, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed PRINCETON monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further and it will help out other people in the future also.
Replacement board: http://www.lcdrepair.us
When i connect my monitor to my laptop it shows the monitor is not picking up any signal. why can't i see anything?
Did you use the Fn key and either F5, 6, or 7 to select the internal, external, or both? It depend on the make and model of the laptop.
Hello.Ihave a princeton vl1919 monitor.The problem is when you press the power button the light comes on for about a few seconds then goes out then you hear a tic tic ticing noise can i try and replace the...
Try looking for bad caps first, see example of failed PRINCETON monitors because of bad caps here: http://s807.photobucket.com/home/budm/allalbums
Post back what you see so we can guide you further.
The ticking sound is from power supply turning on and off.
Upgraded to win 7 now princeton monitor goes black how do i fix
try this, but a bit tricky.
start off with the pc off
then turn it on
wait till the bios etc splash screen show past the hit del or f2 to goi to setup then after that press f8 repeatedly until it shows some sort of list
this is the alternate boot up just scroll down to ENABLE VGA MODE
after selecting that it will boot up with your screen..
hope that works
2answers
The monitor shuts off. Turning the power off
2answers
My LCD Monitor is blinking on & off constantly
It may need a different outlet, if it is not getting proper power. Small chance that the video cable has gone bad, but more likely the monitor is damaged. But try those two things and call Princeton.
Monitor goes blank
Sometimes, i can be the wiring, so check all of that. But apart from that. I don't know! Hope this helps!
DigicalJAI
Top Princeton Digital Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Are you a Princeton Digital Computer and Internet Expert? Answer questions, earn points and help others
