RCA HD52W59 HDTV Projection Television Logo
Posted on Apr 10, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Help I need a replacement screen
I need a replacement screen for a RCA R52WH73 52" that got scratched, where can i get one? Its just the plexi screen.
Anonymous
Level 2:
  • Expert 298 Answers
  • Posted on Apr 10, 2009
Anonymous
Expert
Level 2:
Answers
298
Questions
Helped
304335
Points
615
You can find a new OEM RCA replacement lenticular screen and Fresnal screen (availble together as the screen assembly) for a model # R52WH73 from a major RCA distributor at the following links:
RCA R52WH73 Replacement Part Screen Assembly (Fresnal Screen w/ Lenticular Screen)
And here's a link for the protection screen if needed:
RCA R52WH73 Replacement Part Protection Screen / Super Shield
Looking for Replacement screen For 52" RCA Projection HDTV
You should call a few TV Repair shops. They will have a few of these TV's junked for parts. They will sell you a screen for cheap.
Protector screen is fuzzy
If the picture looks fine without it then yes you can use a piece of plexi or lexan without a proble. It is only for protecting the expensive screens behind it.
I need replacement screens
the inside screens for this tv is screen assmbly rca part number 258513.. the outside plexi is known as the "supersheild" rca part number 258797
Screen is dented
sure no problem. is the screen damaged or scratched...if the inside screen is not damaged then all you have to do is take the t20 torq screw from around the screen and remove the front plexi. remove the brackets that hold the inner screen and straighten it out carefull it easy to scratch.
1helpful
4answers
I need a replacement tv screen for a rca hd52w59 itc222a
I have the 52" set of screens as well, if you still need them, email me @ [email protected] or just reply here.
Rca d52w19 screen scratches
the front protective screen in which rca calls a supersheild. can be replaced quite easy. it cost u bout 70 dollars. a cheaper solution i have heard of is to replace the screen with a thin plexi glass. thats if the internal screens have not been damaged.
2answers
CRACKED SCREEN
the outer screen on these units easly replaced. RCA #258797 their called supersheilds.. rca charges about 70 dollars for the item...If it is just that i have seen people just use a clear sheet of plexi. removeing the screens requires removein several torx 20 screw around the outer and remove the frame.. then the clear peice of plexi is attache with serval brackets.
Scratches on the screen
if the screen prot. is damaged,replace with plexi glass..avail thru local home improvement suppliers...good luck...john
How can I fix a light scratch on the plexi screen
There is a product for polishing platstic that removes minor scratches. I don't however remember the name of the product and if you do obatin it try it in the corner of the screen first to verify it won't do further damage to the screen.
Top RCA Televison & Video Experts
matt martin
matt martin
Grand Canyon Tech
Grand Canyon Tech
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
