I own a hitachi nr90ae framing nailer and i noticed oil coming out of the trigger assy. ive also had this happen on my other hitachi nailers,finish and brad nailer,my question is, is this normal? thank you
Oil leaking out of the nailer anywhere is just an indication that too much oil is being introduced. A good solution would be to reduce the amount of drops until no more leaks out or use an in line oiler at the gun. An oiler costs under ten dollars and feeds in oil vapor as you use air. Store / hang your nailer with the air inlet down at night to drain out access oil. Do not worry too much about the leaking though, I think that a bit too much oil is better than a lack of oil. Good luck.
