You need to check the exciter circuit for the gen field. If there isn't a voltage regulator, there is going to be a circuit feeding the field. It could even be a 'permanent magnet' rotor inducing the voltage for the stator.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/craig_3fa289bf857b1a3c
SOURCE: Checked capacitor, diodes and circuit breakers and
Make sure it is not the brush set.
There must be continuity from one slip ring to another.
If not, but rotor doesn't look burnt - check points where rotor wire is soldered to slip rings, or clear contact point on each side of wire and check continuity there, past slip rings and brushes. Big chance that wire came loose from slip ring.
Had such problem on my Champiion 3500
evern if burnt - rotor is easy to rewind at home, unlike stator.
Unless your model is Inverter type - there is AVR module.
But, unless your rotor has continuity - don't bother going further.
SOURCE: no output voltage for powermate generator
NO. the capacitor resonates with a winding it is in parallel with as part of the voltage regulation.
Recharging a brushless generator can be tricky. I have had success using two 150 watt lamps in series between the running generator and the electric utility power. Search google for this method.
That kind of spark usually indicated a shorted or grounded rotor. You say that you have tested the windings, but did you test the rotor windings as well? What about the brush / slip rings?
