Question about KitchenAid KCMS145J Microwave Oven
I have a Kitchenaid microwave Model # KCMS1555 RSS all works but just doesnot heat food. What could be the problem? Is it fixable? How much $$$?
2 Suggested Answers
SOURCE:
MicrowaveSvc
  • 9174 Answers
SOURCE: KitchenAid Microwave Model KCMS1555 does not work
Assuming your inside light, turntable, and internal cooling fan all come on when you try to microwave, with the symptoms you have, I would most strongly suspect a shorted high voltage rectifier diode or a bad magnetron, or a loose and possibly corroded connection on the magnetron's terminal.
The diode is a fairly cheap fix, and the mag will cost more.
If you or someone you know decide to look into it, we have critical safety information and disassembly information at our site, and our link is at our listing here on FixYa.
There should be a "mini-manual" (tech sheet) hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting, testing, and locating components.
d:%5cele%5crepair%5cmicrowave%5cge_hotpoint%5cmini_manual_behind_grille_small.jpgAt our Web site, we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
If you don't find your mini-manual, or if you want to look at it before removing the controller, you can download it here.
Here are some links you or someone you know can use for test help, but read their safety warnings first:
http://www.gallawa.com/microtech/diode.html
(if it's not shorted or burned, it's probably okay)
http://www.gallawa.com/microtech/mag_test.html
http://www.gallawa.com/microtech/xformer.html
http://www.gallawa.com/microtech/cap_test.html
You can find links to helpful exploded view diagrams and part ordering help here. I recommend that you bookmark that link to your favorites.
Accessing some components for testing and possible replacement will require you to remove the oven from the wall.
If so, the installation instructions are very handy, and it's best to have two people since the microwave can be heavy and awkward.
You can download owner's manuals and installation instructions for several brands (including Amana, Jenn-Air, Kitchenaid, Litton, Maytag, Roper, Tappan, Thermador and Whirlpool) here.
If it's within the magnetron portion of the warranty (usually 5-9 years) but out of the original full warranty (usually 1 year), then your manufacturer will cover the part cost, but not the cost to visit you (usually $75 -90) or the labor charge to do the work(usually $75 -90 more) . See the model tag in or on the unit for the date of manufacture.
If nothing else, you can save about $75 by taking it to the shop yourself.
Posted on Dec 07, 2009
I have a KHMC106W Micro-Convect Hood - all of sudden when we used the microwave it didn't sound right and the food never heated up. I unplugged and waited about 2 min and replugged back in and it still...
the Magnetron has gone (yes it's really called that) that's the part of the microwave that emits radio waves and cooks your food... 30 years ago when this tech (Microwave cooking) was new and expensive it was cheaper to replace that part than buy new... now it's the other way around... at least you still have a working electric convection oven.
it's very rare that a Magnetron go bad, so look for an old one of the same model and use that one for parts if it's that loved.
Nov 18, 2017 | KitchenAid Microwave Ovens
Microwave heating for 20-30 minutes with no food. Does not work.
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101
hgj
Jun 02, 2010 | GE JVM1630 Microwave Oven
Dec 06, 2009 | KitchenAid Microwave Ovens
My microwave sounds like its working but is not heating food
More than likely, what has failed is called a "Magnitron" and you can find them online and replace, you may have to take your unit out verify what model it is, and sizes. but yes fixable.
Nov 09, 2009 | Microwave Ovens
MIcrowave doesn't heat up food
heatman101
fdyjhd
Jul 18, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
It turns on ...lights up but doesnot heat or warm the food
Sounds like the magnetron has failed. This is the component that produces the microwaves that heats the food.
The cost of the magnetron is about 95% of the cost of a microwave oven. Most people don't, for this reason, replace the magnetron, they replace the whole oven which is probably what you will end up doing.
There is a possibility that the circuit that provides power to the magnetron is faulty and you need to take it apart, find the proper electrical leads and test them with a volt meter. To do this you have to remove it from its mounting and take it apart. It is a fairly lengthy process however.
Benjamin
Apr 17, 2009 | DeLonghi MW 605 Convection/Microwave Oven
GE PRofile Microwave runs but no heat
This is a sure sign that the magnatron needs replaced ( This is what heats the food!) replace and all will be good again!
PLEASE rate my response to your question
Thank
You!
Jan 10, 2009 | GE JVM1870 Microwave Oven
Convection oven problem
Most of the time the magnetron is defective if the food is not heating up.
In some cases there is a defective low power transformer or other componenents associated with the magnetron.
I would suggest to check the owners manual under the warranty section. Sometimes the magnetron has 5 years warranty.
Good Luck.
Feb 15, 2008 | GE JVM1490 Convection/Microwave Oven
KitchenAid KCMS145J Microwave Oven Logo
137 people viewed this question
Top KitchenAid Microwave Ovens Experts
William Miller
William Miller
Thomas F. Schneider
Jaime Hernandez
Are you a KitchenAid Microwave Oven Expert? Answer questions, earn points and help others
