SOURCE: Tag Heuer Aquaracer calendar problems
You have to unscrew the knob first then you will be able to pull it out to change the minutes, hours, date. You may have to use a pair of small pliers to initially turn the knob.
SOURCE: looking for the user manual for Tag Heuer Aquaracer watch
They were just hiding it:
http://ww2.tagheuer.com/_documents/manuals/EI2252_en.pdf
-Tha Mp3 Doctor
SOURCE: Tag Heuer CA 1211-RO Min. Hand resets to 59 Min.
Unscrew the crown and pull out halfway. Use the stopwatch buttons to advance the hand to where you want it. Then push the crown back in and screw it down. You may need to pull the crown out all the way--I cannot recall which setting controls the minute hand and which the hour hand on the stopwatch function. This has to be done every time the battery is changed.
SOURCE: My tag heuer aquaracer has a problem: the second
Your TAG is fitted with EOL (end of life) feature. This is the cause of
that 4-5 seconds interval movement of seconds hand and thus indicating
the time for battery replacement. The timekeeping is not affected by
this- it is just warning to replace battery a.s.a.p.
Find your nearest watchmaker and ask for battery replacement.
Do not forget to rate, please.
SOURCE: Tag Heuer Aquaracer reset red hand
THANK YOU THANK YOU THANK YOU!!! I had a similar issue and this saved me!!!!
