Changed sand now the multiport valve is leaking at very top?
Is it leaking at the joint between the tank and valve, between the two halves of the valve, or from the center of the valve (around the handle)? If It's either of the first two, you may need to replace the o-ring. Take it apart, and check to make sure the o-ring is in good shape, and seated properly. If the o-ring is flat, oblong, or leaving black on your hands, then you should replace it. If it is leaking around the center of the handle, then you need to replace the o-ring and/or teflon seal on the shaft of the stem assembly (the part the handle connects to. To get to this you need remove the top half the valve, then drive out the pin that holds the handle on. (make a not with direction the handle and the stem are. otherwise you can be 180 degrees of when you put it back together. Hope this helps. If you need further assistance post a reply in the comments, and don't hesitate to leave a good thumb rating if you found this helpful. Thanks, and good Luck!
