Always need to restart computer to print twice. The first time it works and then I always need to cancel the printer. Then next print won't print.
Here is the solution for your issue:
1.Click Start, and right-click My Computer.
2.Click Properties, then click Hardware.
3.Click Device Manager.
4.Double-click the Universal Serial Bus Controllers branch to expand it.
5.Right-click USB Root Hub, and then click Properties.
6.Click Power Management.
7.De-select the Allow the computer to turn off this device to save power
check box.
Note: If the Root Hub is listed twice in the Device Manger, perform the
steps 5 to 7 on the second entry.
8.Click OK, and close Device Manager.
Please let me know if the above solution does not work. I would be glad to
help you further..
Fix your printer with this small utility!
Has your printer quit working? Did you try to cancel a job and it broke the printer completely? I always do that. And the method to fix it usually involves rebooting, restarting the print spooler, trashing junk print files, and sometimes even more. Not anymore.
Print Flush has a simple function: clean the print spool. If your printer's driver is incorrectly installed, Print Flush cannot help you. If you have used your printer before and it worked fine then, but it doesn't now, Print Flush can probably help you.
It also works with Vista.
http://www.bradkovach.com/printflush/
