Most blue tooth device manufactures use the power button to set your device to discovery mode,first you must turn the power to on for your blue tooth from your phone menu,then most manufactures use the power button to put the blue toooth device into discovery mode,by holding the power button down when you turn your device on holding it for 6 to 10 seconds,usually a solid light appears on your blue tooth device,it is now in discovery mode,on your phone menu there should be an add new or search devices,once you've clicked that it should discover your blue tooth device,then you will need a pin or pairing code,Most manufactures use a factory 4 digit pin pairing code the y are as follows 0000,1234,1111,or 9999, if you have done the steps correctly the menu will say connect,press conect and you should be connected..i hope this helps
Most blue tooth manufactures use a factory 4 digit pin pairing code,motorola uses 0000,and 1234,even though they are the most common of the codes used to pair a blue tooth device there are two others that i know of,and they are 1111, or 9999,now in the 10 years that i've dealt with blue tooth technology i have yet to come across a blue tooth device that has not used one of these 4 codes,so try these first from the most common ones first,then if it is nessasary to try other ones try the last two,but 90 percent of blue tooth manufactures use the same technology witch in this case would be the same codes..i hope this helps..thank you
In order to set up your blue tooth device to your phone you first must turn your blue tooth power to on in your phone menu then you must turn your blue tooth device into discovery mode.this usually is done by holding the power on for 6 to 10 seconds and a solid light will be on,then in your phone menu you can add or search for blue tooth device if you have your blue tooth in diuscovery mode the two will pair then you must enter a pin or pairing code,most manufatures of blue tooth devices use a 4 digit factory pin or pairing code they are as follows 0000,1234,9999 or 1111 enter the code and they will pair ,once paired it might ask you to connect ,selet ok or yes and your in business, i hope this helps
You have to put your blue tooth device to discovery mode usually you hold the power button down for 6 to 10 seconds when turning on you blue tooth device then you will have to make sure to turn your blue tooth power on in you menu then you can add or search device once they pair you will need a pairing pin code .Most blue tooth device manufacture use a factory pin pairing code they are as follows 0000,1234,9999,or 1111 i hope this helps
Hi, It all depends. When you want to connect a blue tooth to a phone, You will need to switch on the blue tooth device and the phones blue tooth you are pairing with.
When pairing both device, you will ask for pairing code, You four digit numbers(default code(0000). and pair.
After pairing both device, you detected paired, you can now use the blue tooth device with your phone.
there are no special code for pairing Blue tooth device. Normal codes used are any four digit, four numbers you want to use.(0000, 1234).
Hi, you will need pair both phones together before you can be able to send .
both party A and B blue tooth should be on
from nokia 6700. go to settings , connectivity , blue tooth
open . turn on blue tooth . and scan .. click on the party B ( buddy phone ) confirm the name from the other person whom u want to pair and then sent a req ( it ll be asking for pin. use any pin of your choice i.e 123 and the party B ll be prompt for a pairing n enter pin. he must enter the same pin u have put in on your phone before sending a req, it ll be done
blue tooth will not pair with my new blackberry 8320. keeps asking for a pin. i dont recall setting one up and dont have the manual anymore to remember the basic one it came with.
