You should first make your phone ready to be connected to PC....Goto settings>>connectivity>>PC......
if you still cant get Manual for your phone to know more about it by clicking here
ALTERNATE WAY TO TRANSFER PHOTOS AND VIDEOS TO A COMPUTER If your photos and videos are stored on the memory card, then remove the memory card from the camera and insert it into an USB memory card reader. Connect this USB memory card reader and memory card into the USB port of your working computer. Your computer will see this as an USB Mass Storage Device or an external storage device; you can then open the folder on the memory card and copy the photos and to your computer. Memory card reader is a handy device and is inexpensive. You can copy photos from other cameras and you can also download photos off your memory card to someone else's computer without the need of installing any programs.
hello friend, i am also having the same mobile. this mobile will not support samsung studio pc suite. just go to samsung official website and select phone samsung gt-s3310/I. from here you can download samsung kies software. before installing this sotware in your pc, you should install dotnet frame work 3.5 offline version and also windows media player 11, also download and install data cable driver for samsung gt-s3310i. thats all ...enjoy
Disconnec the phone from the PC.
insert the Disc and run and install the Samsung PC Studio on the PC.
Now reboot the PC.
Connect the phone to PC via the USB cable.
And the PC should say SGH G600 connected.
The with the help of file manager on the Samsung PC Studio, xfer the pics to whatever folder you want.
I had this problem before, You have to specify what type of USB settings you want. go to phone settings, then USB settings and pick from "PC Studio", "Ask on connection" or "Mass Storage". hope that helps!
GO TO MENU SETTING SELECT PHONE SETTING THEN GO TO THE USB SETTING THEN SELECT MASS STORAGE PUT THE USB IN THE PHONE. THAN SWITCH THE BLUETOOTH. THAN IT STARTED TO LOAD UP. IT WORKS FOR ME I JUST TRY IT.
make sure that ur using the 2.0 port of ur computer
dont use front usb ports cpu. use rear ports. they are faster.
if still problem persists. try below
conect ur phone to usb. now without disturbing the connections switch off and then on the phone. now there may be chances.
samsung sofware could be corrupted due to virus on ur pc. remove all the viruses then freshly install suit
that's the link with driver for samsung SGH J700 works perfectly with my phone http://www.samsung.com/au/support/download/supportDown.do?group=mobilephone&type=mobilephone&subtype=megapixelphone&model_nm=SGH-J700&disp_nm=SAMSUNG%20J700&language=&cate_type=all&dType=D&mType=SW&vType=R&prd_ia_cd=01011800 kisses all :*
>> To transfer files using PC Studio, from a PC to the handset, follow the steps below:
These instructions assume you currently have PC Studio. If you do not, please check the Samsung Accessories site to purchase the software.
If the application is not yet installed, insert the CD into the drive on your PC and follow the on screen instructions to install PC Studio 3.0 (version 3.0.1) NOTE: DO NOT CONNECT USB CABLE DURING PC STUDIO INSTALLATION
Confirm the handset's USB mode is set to PC Studio by following the steps below:
While in standby mode, press the left soft key for Menu
Select Settings (9)
Select Connectivity (6)
Choose Select USB Mode (4)
Highlight PC Studio, using the navigation keys
Press the left soft key to Save the USB Mode settings
Launch PC Studio 3.0 (version 3.0.1), you will see "Not Connected" in the bottom right corner
Plug the USB cable into both the handset & the PC, you will now see "SGH-a727 Connected" in the bottom right corner (See example below)
Click on Transfer Files, you will now see the PC Studio Phone Explorer appear
Navigate to the location of the file(s) to transfer then highlight the desired file(s)
Click on To Phone, on the Phone Explorer menu bar (See example above) to copy to the handset
From the Search Folder screen, Navigate to the desired destination on the handset
Click OK to copy the selected file to the handset's memory
PC Studio Checklist:
Make sure your USB or Serial cable is compatible with your phone model. You can always check for the correct data cable by looking at the model number on samsungmobile.com in your phone's accessories section.
If you are using a Bluetooth dongle or IrDA port as your connection, the necessary driver(s) should be provided with their data kit and should be correctly installed and set up prior to the installation of PC Studio.
Hints & Tips:
Remember to select file formats and file sizes supported by the phone when uploading files to the phone from the PC.
Remember to select the correct destination folder in the phone when uploading files to the phone from the PC (e.g. mp3/aac files-> music folder, jpeg/gif files-> downloaded images folder, 3gp/mpeg4 files-> downloaded videos folder...)
Uninstall any current samsung software, then go to the link below and download the software required, but it may be that the usb port is not powered enough to aknowledge there is a phone connected, so try another usb port or try on another pc, to illiminate the usb lead as the fault.
http://www.samsung.com/search/search.asp?charset=utf-8&ht=0&qp=&qs=&qc=&pw=755&ws=0&la=en&qm=0&st=1&nh=10&lk=1&rf=0&rq=0&si=1&ct=None&oct=&oq=%0D%0A&fs=&oqqtex=d520&bqt=d520&th=0&ts=1&selradio_temp=&qt=d520&tabpage=3&radio=1&col=download&select=0#
