Cars & Trucks Logo
Anonymous Posted on Aug 24, 2013
Battery drain in a few minutes
My battery is draining immediately the engine starts
  • ARESTI
    ARESTI Jan 25, 2015
    Hi bonon371, I want to help you with your question, but I need more information from you. Can you please add details in the comment box?
homefixit
Level 2:
New Friend:
  • Expert 54 Answers
  • Posted on Sep 07, 2016
homefixit
Expert
Level 2:
New Friend:
Answers
54
Questions
0
Helped
25198
Points
126
Sounds like alternator (generator) is at fault. Voltage at battery should read about 14 volts when charging. Sometimes onlythe regulator (diode pack) on alternator is at fault some can be changed without having to have a new alternator (not sure about yaris)
5 Related Answers
Anonymous
  • 18 Answers
  • Posted on Aug 13, 2008
SOURCE: battery draining fast
I would check the alternator again, it apparently isn't charging the battery with engine running. You need a volt meter or amp meter to test this. Also does the battery discharge when the car is not running?
Anonymous
  • 247 Answers
  • Posted on Nov 29, 2008
SOURCE: electric fans runs after car is shut off, drains battery
Having the fan run on for a bit after the engine has stopped is not abnormal in itself, but 20 minutes sounds excessive.
If the fan does eventually shut off, I'd consider changing the thermoswitch (this is a sensor screwed into the radiator somewhere near the bottom, with a pair of wires connected to it - to change it, you'll need to drain the cooling system).
If the fan stays on continuously until the battery is completely flat, see what happens when you unplug the wires from the thermoswitch. If this stops the fan, you need to replace the thermoswitch. If it doesn't, then you need to examine the wiring associated with the switch and the fan, looking for damaged insulation.
A.
Anonymous
  • 9 Answers
  • Posted on Jan 26, 2009
SOURCE: the battery keeps draining and
This may be over-simplified, but to find the battery drain: Remove the positive battery cable from the battery and insert an ammeter in series beween battery and cable. If something is draining the battery, it will show on the ammeter. Remove fuses one-by-one until you see a substantial reduction in the ammeter reading. That will pinpoint the circuit that is draining the battery. Then troubleshoot until you find the faulty component, wiring harness, etc. Remember there will always be a little bit of drain because of ECM, BCM, radio memory and stuff like that.
Anonymous
  • 1990 Answers
  • Posted on Jan 30, 2009
SOURCE: battery not charging sometimes, drains out while driving
You have a Bad Belt Tensioner. That is Causing your Problems. If the Tensioner is not Keeping the Belt Tight you will get the Symtoms as Described Above. Please Rate my Solution, I need all the Help that I can Get! Thanks!
Anonymous
  • 82 Answers
  • Posted on May 08, 2009
SOURCE: peugot expert van draining battery when everything
either change the battery or the alternator,,just either of those,,,if your battery is no good it wont hold charge when started,,,also if your alternator is no good it wont charge your battery when engine is running,,,(it can also drain your battery if faulty)..get a second hand alternator in a breakers yard maybe a batt too much cheaper,,,hope i helped you,,
No light can come up including ignation key
check vehicle battery connections for obvious corrosion. If none is present, use another vehicle and battery jumper cables-properly hooked up, and with 2nd vehicle idling, try cranking Toyota. If not immediately starting, give it a few minutes to charge toyota battery, and then try again. A fully drained battery will require several minutes charge from second vehicles charging system to sufficiently charge drained battery.
What is platform zone module
Seems like the altinator is not charging the battery, charging should be more then 13 volts while engine running.
Silverado gauges stop start
sounds like a bad starter solenoid switch or a fusible link most likely a bad starter solenoid
1helpful
2003 Mitsubishi Galant 2.4L 4-cyl is having trouble holding a charge on the battery. Tests say battery and alternator is OK. I checked fuses and they were good. I can jump the car but after I drive it...
Most likely you have something draining the battery. Quick way to tell, disconnect the ground (negative) cable to the battery, let it sit for a few hours, then reconnect it and try to start it. If it starts OK, you know the battery is holding a charge, but something is draining it.
To drain it in just a few hours requires a serious draw, like headlights or the cooling fan. It is possible that your cooling fan (behind the radiator) is staying on all the time. Often they are controlled by a thermostat, and will run for a few minutes after you shut off the engine, but it should shut off within about five minutes. If it is still running after ten or more minutes, you have a bad fan thermostat or a bad fan relay. If that is not the problem, you will have to get someone with an ammeter to measure the current draw, and start pulling fuses until you find the culprit.
MY 2005 GMC will not start on a regular basis but if I have the battery charge designated to the 'Car Start' designation, the car starts immediately. When I start it without that it seems to drain the...
A short this bad is usually in the alternator--blown diode. Try disconnecting the alternator to see if it helps. Be sure to remove the negative battery terminal before taking wires off the alternator. Then wrap the alternator wires with electrical tape before reattaching the battery terminal. Start the car and see if it works right for you (battery light will be on, but that's OK for a short test). If that works, take the alternator off and have it tested for shorts at the parts store.
If that doesn't work, hook the alternator back up and check other circuits for shorts.
Please see my tip at http://www.fixya.com/cars/r5925550-dead_battery_troubleshooting . These are generic instructions. If you get stuck or need specific instructions for your car, please get back to me with model, year and engine info.
3helpful
2answers
OMG!! its a nightmare! Help!! i turned my navigator this morning and the battery light stayed on the dash board...when i accelerate it either blinks or goes off for a few and it comes back on...i had put a...
Yes. There is a very good possibility that your alternator is beginning to fail. The battery only starts the car and maintains nominal accessories. The alternator on the other hand actually provides the fire/spark for the engine after it has started o keep the engine running.
The light coming on and off is indicating the alternator is failing or falling below what is needed for the engine. When this occurs the system defaults to the battery, where it drains the battery. At higher speeds/RPM's the battery light is probably turning off - right?
A very easy way to check this is to start the vehicle, and with the engine running, remove the Negative (black) Cable going to the Battery. If the engine dies, it is the alternator and needs to be replaced immediately. Once an alternator fails, it will drain and kill the battery.
1helpful
Peugot expert van draining battery when everything is switched off When jumped started the battery charges quickly, but switch off the engine and in ten minutes the battery is totally drained. Help greatly...
2answers
Electric fans runs after car is shut off, drains battery
A.
Top Toyota Experts
ZJ Limited
ZJ Limited
Ronny Bennett Sr.
Ronny Bennett Sr.
Thomas Perkins
Thomas Perkins
Are you a Toyota Expert? Answer questions, earn points and help others
