Question about Yamaha 12V Air Pump
Have 1997 yamaha gp1200...starts and idles fine...runs fine for first five minutes then just loses power or shuts off. Wait a couple minutes...starts back up runs great then loses power to idle or shuts off. Checked fuel lines, fuel filter, vent hoses, carbs clean, oil lines zip tied tight, compression good, checked kill switch, disconnected thermoswitch and ran....still does it. Someone mentioned rectifier/regulator and cdi? Any help appreciated!
    Sergeant:
  • 216 Answers
Check the converter on the exhaust they do plug up if on too long
Posted on Jun 21, 2017
    Top Expert:
  • Yamaha Master
  • 53,745 Answers
Indicates that a component in the ignition circuit is overheating internally and failing
could be a coil or cdi unit or any sensors if fitted
5 Suggested Answers
SOURCE:
finish line
  • 207 Answers
SOURCE: Ran my Yamaha GP 1200R Out of Gas
you cant clean the carbs out once u take the diaphrams out u just need to replace them get three carb kits from riva yamaha and put kits in them and ill bet you $20 it will run
Posted on Jul 08, 2009
finish line
  • 207 Answers
SOURCE: I have a 2002 Yamaha FX140 Waverunner.Fuel problem or electronic?
you have fouled spark plugs change them all fixed all the newq yamaha sare doing it it is the in thing to do
SOURCE: 1994 Yamaha Waverunner 3 will idle but wont take throttle
Switch to reserve tanke to check to see if there is a clog at the fuel pickup in the tank.
My friend had the same issue with his waverunner 3.
Posted on Aug 31, 2009
heimlich
  • 1978 Answers
SOURCE: 1998 yamaha waverunner xl760;just purchased it
Take the carburetors apart and clean them. There is probably water caused white corrosion in the fuel needle assemblies. Once the needles are cleaned the fuel should pump and flow through the carburetors again.
Posted on Sep 27, 2011
2010 Ford F150 would suddenly loose power and only idle. Pull over shut off sit a couple minutes crank and run fine for a while then do same thing again. Wrench would show up on instrument panel
Sounds like the catalytic converter or muffler maybe getting plugged up and the computer is putting the truck in limp home mode. Did you put a scanner on the truck. You might try to remove the 02 sensor ahead of the cat and see if it runs a little better it will not be perfect but should stay running if so do an exhaust check. When the cat or muffler gets plugged it puts back pressure on the engine and won't allow the fuel to be pulled into the engine properly.
May 19, 2017 | Ford Cars & Trucks
I have a 1997 SAAB 2.0 Turbo and it has started to run rough after it warms up and when driving it loses power and runs very rough until power taken off. Any ideas?
suspect low fuel pressure to the injectors
run the fault codes to determine where the fault may be before you spend money
Oct 09, 2015 | 1997 Saab 900
1997 yamaha mountain max 700 runs but then boggs then runs normal again
will most likely be the Carburettor is dirty. WHAT CAN YOU DO for this; In the market there to spray purified karmpylater.
DEDUCTIONS after the air filter, the engine ignited and psekazeis the contents of the spray inside the karmpylater while playing with the throttle
Nov 27, 2013 | Motorcycles
It will run good for a while on hot heat and then shuts off for abut 5 mins but it doent shut off on cold cyc
why does my roper electric dryer shut off after five or ten minutes of running fine. then wait five or ten minutes, restart and it runs fine for another five or ten minutes, and so on....
Dec 29, 2012 | Roper REX4634KQ Electric Dryer
High idle 1997 gp1200
obviously your fuelling isn't set up correctly
Jul 13, 2012 | Yamaha 98 Gp 1200 Air Box Intake Mount...
Car runs for about five minutes then shuts off
1999
mit eclipse runs for five ten min then shuts off i have to wait a while befour starts back up why?
Apr 13, 2010 | 1997 Mitsubishi Eclipse
Truck idles fine but has no power
Does the exhaust sound muffled? Could be a bad catalytic converter.
Mar 05, 2009 | 1999 GMC Sierra
Yamaha 12V Air Pump Logo
1,904 people viewed this question
Top Yamaha Water Sport Experts
boomanfoo
Level 1 Expert
Craig Butler
Craig Butler
Marvin
Marvin
Are you a Yamaha Water Sport Expert? Answer questions, earn points and help others
