I have seagate barracuda 7200.11 st3500820AS Firmware SD35
and i have important data in harddrive. complit lot of 500gb harddrive is defective
This problem is a product bug of seagate,and you can repair this bug when it is ok,but once it corrupt,then you cannot repair the bug by update it,you should first use some tools to repair it and then update the firmware of the drive,any questions pls kindly feel free to contact with me:[email protected]
Get a hard drive kit that will connect it via usb or get a PCI card that will allow you to install the PCI card into a PCI slot and then attach the hard drive to the PCI card ( ensuring you select the correct PCI card ) ie if its a sata drive then get a sata PCI controller card and if its IDE then get an IDE PCI controller card.
Also check for motherboard updates for your computers motherboard and also check in the bios to ensure LBA is enabled and that its detecting the hard drive.
