start at pump with key on test for power then move to under dash or where you fuse block is test for power at the fuel pump fuse or it may fall under a different fues there is a sercut for the pump relay like on a jeep wrangler if fuel pump wont work it is the dome light fuese that completes the sercut for fuel pump relay (yes i said dome light fuse for fuel pump relay its true) as funny as it seems that is true so perhaps yor yota is same also somtimes a fuse will test good but is coroted or rusty try changing a couple of fuses that may seem corted or rusty or dirty looking beleve me it is somtimes the dumest things that are the hardest to figure out also try switching a relay with another to try it or try fallowing the wires could be bad or coroted ground as well do you do alot of off roading with it
With some new cars they have an amplifier for your speakers. You might have blown a fues to this amp. This amplifier should be in the trunk. But the fues might be with all the other fueses.
Locate the Fuse Relay box under the Hood. In this Box are Relays for a lot of things one Being the Fuel Pump. Replace the Fue; Pump Relay and Check the Fuel Filter and Fuel Pump. Please Rate My Response! Thanks!
