SOURCE: Our American Standard toilet flushes
Okay Howard. It seems that the fill or float valve inside the toilet tank needs to be replaced. If you have a pair of channel locks / large pliers and some patience, you can do this yourself and save $ on a service call. This Solution is providing that you have good water pressure everywhere else in the house. First turn off the water on the supply line going to the tank. Flush the toilet (with the water off) to empty the tank. Take a towel / sponge / or wet vac to remove any remaining water. Remove the nut on the underside of the tank that holds the float / water supply to the tank. Now that you have the water float removed you can go to your local hardware store / Home Depot / or Plumbing Supplies Store and get a new fill valve. There are different kinds but they all do the same thing, fill your tank. I use a Fluid Master, But you may have to use one like you have. The Store will assist you. They are only about $10 - $15 Bucks or so.......Install the new float according to directions.....It is pretty simple. Insert your new float stem into the hole with the proper rubber washers and tighten carefully for a good seal. Insert the new black hose into the overflow tube and you are in business. You will have to adjust the water level to about a 1/4 Inch below the overflow tube for a good flush!!! I hope this helps you with the slow tank fill.............Joe
SOURCE: American Standard Champion toilet keeps running
Readjust the float. the longer it is the more leverage the fill water will have on it. good luck. The fill valve does come apart and cleaned if there is debri in it. Turn the water off first:)
