Do you mean the size of the engine? Or the stamped number on the block.
The engine size is on an identification plate usually at the rad support.
The number on the block is hidden, normally you can't see it unless you dismantle quite a bit of the surrounding parts.
If there is more information you need, you can take your VIN number off the dash and call a dealer with it. They can supply you with almost all the information about your vehicle from that number.
If your SIM got blocked, it will be asking you the PUK number. Call the customer care of your mobile operator from other no., and ask for the PUK no. Also brief the customer care regarding your SIM blockage, due to pin code.
There are a number of ways to accomplish this if you need to.
Normally your landline phone company will have a paid monthly service called CALL PRIVACY, or CALL BLOCKING, or CALL SCREENING, or some other name like that. Each local phone service provider will have their own name for their particular version of this product so you will have to contact yours in order to find out the exact details, operating instructions and cost.
This service will effectively allow you to block certain numbers from calling your home phone. You can either enter the numbers into the system manually, or if their Caller ID is hidden, then just press a certain key sequence right after they call in order to automatically add them to the block list.
After that, your phone will no longer ring at all when that number calls you and the calling party will hear some kind of automatic rejection message and then be disconnected.
Generally this service will cost a few extra dollars a month on your phone bill and will normally allow you to block up to about a dozen separate numbers.
If you need to block more numbers than that, then you may need to set up your own customized call blocking system using a home computer hooked up to your home phone landline. There are a few excellent software programs you can get which will monitor the incoming calls to your home phone line and automatically block any that you designate as undesireable.
As I said, these customized call blocking systems normally require you to have a basic home computer system connected to your phone line and running full time. If this is not objectionable and you have an older spare desktop computer system lying around, then it would not take much effort to set it up. The main advantages to this method are that there is no limit to the number of callers/numbers that you can block, and the only paid monthly subscription you require from your local phone service provider is their Caller ID feature.
Here is a link to one excellent software program that you can download and use completely for free:
Just use your mouse to click on the link, which is the underlined and highlighted text just above. This will open a new web browser page automatically for you and allow you to view the information at the website indicated where you can read about the software, check out other user's reviews, and download it completely for free if you decide you want to try it. This particular program offers many additional options as well beyond just simple call blocking if you want to get really creative, but a basic system is pretty easy to setup if that is all you need.
Using Call Block If you subscribe to Caller ID, you can save phone numbers to the call block list. When a call comes in, the phone compares the received phone number to the numbers on the call block list. If the phone number is on the list, the phone replaces the caller's name with Call Blocked and disconnects the call. (The caller hears a reject tone.)
The call block list holds 20 entries, and all stations share the same list. You can add entries through the Call Blocking menu, by selecting Add Call Block in the CID menu, or by blocking incoming calls. (Only one station can edit the call block list at a time.) Blocking incoming calls
When the phone rings, wait until the display shows the Caller ID information (usually after the second ring).
If you want to block the call and add this number to the call block list, press Block.
When the phone asks you to confirm, press Menu/select or Block. Blocking an incoming call from an "Unknown" or "Private" number is the same as selecting Unknown Number or Private Number from the Call Blocking menu.
Call Blocking menu options
With the phone in standby, open the menu and select Call Blocking.
Choose one of these options:
Create New(Handset only) - Add an entry to your call block list. The phone will prompt you to enter a name & phone number.
Private Number(Handset only) - Block all calls from numbers reported by CID as "Private." (This does not count as one of the 20 entries.)
Unknown Number(Handset only) - Block all calls from numbers reported by CID as "Unknown". (This does not count as one of the 20 entries.)
Call block entry options
With the phone in standby, open the call block list and find the entry you want.
Press Menu/select to open the individual entry menu. Choose one of these options:
Edit(Handset only) - Edit this entry. The phone will prompt you to edit the name & phone number.
Delete - Erase this entry from the list & allow calls from this number.
When you say block the cell phone number what exactly are you referring to? Is it to prevent a particular number from calling you or you want to hide your phone contact number? In the first case you will need to contact your service provider customer care center to provide you with a call barring code. If you want your number hidden just add #31# infront of the number. Hope this solution has been helpful?
from menu,go to settings on your phone>call settings>send caller identity, press on your send caller identity, you will off option, select and save. you number is now hidden when making out going calls.
Handy Blacklist protects your time and peace of mind by keeping undesired calls off your phone. If there is someone you just don’t want to hear from, let Handy Blacklist keep that person off your phone! 2 types of lists with different functions will keep unwanted calls hidden from your eyes. You have one blacklist and one or several Allow lists. Only one list can be activated at the moment. Blacklist contains numbers you want to be blocked. You can add numbers from recent calls, contact list or just by typing them. If you reject a call manually, the software will propose you to add that number to blacklist automatically! Blocking of Private and Unknown calls is also available. Allow list contains numbers which will be allowed to receive while others will be rejected. In addition, you can choose a "reject" action to return a prewritten text message back to the caller. A notification of the missed calls appearing in a popup note can be set by user as well.
