eMachines T5274 Desktop PC Logo
Anonymous Posted on Aug 24, 2013
Ihave an emachine desktop pc t5274. ineed to find wireless network icon.
Hammer Time
Level 3:
  • Master 884 Answers
  • Posted on Aug 24, 2013
Hammer Time
Master
Level 3:
Answers
884
Questions
Helped
233556
Points
2685
Have you installed a wireless card? It likely doesn't have one. Most desktops don't come with one.
1 Related Answer
Anonymous
  • 2229 Answers
  • Posted on Nov 13, 2010
SOURCE: Where do I plug in
When looking at the motherboard with the back of the computer to your left, there should be a row of pins on the lower right corner of the motheboard (or close to the corner). These pins are normally marked as something like PLED (for the power LED), PWR SW for power switch, RST for reset, IDE LED for the hard drive light, etc.
The power switch is normally along the bottom row and the power LED is on the top. But--to find where the power switch goes, take a small screwdriver and short two of the pins to see if the computer turns on. If it does, you've found the power switch. When the computer is running, put the power LED plug across two pins to see if the power light lights. If it doesn't, try two more until you find it.
var fctb_tool=null; function FCTB_Init_88a0199091e74aa0ab8dd27b901b03c6(t) { fctb_tool=t; start(fctb_tool); }
Installed woreless adapter driver and now machine powers on but with loud alarm and no os loads
Might check your bios settings please make sure u have the latest bios firmware as for wireless i ran into trouble with pci wireless cards had to get a usb wireless adapter hope this will help also if the os but check ur bios settings hope that will help or lead u in the right direction ;-)
What kind of wireless card do i need for a t 5274
Pci wireless card b.g,n check you have a spare pci slot in the pc
Diagram emachine wiring
There is no specific wiring for eMachine. your wiring goes from power supply (big box with fan) to motherboard (large board with many components) to hard drive, cd rom, fan, etc. pretty easy to figure out if you look closely
How do i enable wireless in my emachine desktop computer?
You didn't provide the Model of the eMachine or the OS. So a general procedure , if you have a Wireless Adapter, Look in the Tray Notification Area for the Network icon, right click, open Network and Sharing Center, open Change adapter settings, Is there a wireless adapter listed? Is it enabled? Do you have "Fn" keys the turn the wireless on and off? In your user/setup manual it should have all the info. Post the Model of the machine and we can be more presise.
I have a emachines T5274 with vista home Premium.... and when i turn in on the Emachines logo pops up BUT stay up for a long time around 1-2 mins and it use to be around 4 secs!! then it goes into the...
It sounds like you may be trying to load a lot of temp files.
Go to CNet.com download Advanced Systems Care "Free Edition"
Follow the directions to clean up your system.
If that does not fix the problem Download a copy of Glary Registry Repair (also free) and run that.
These are two of the best software packages to have.
I have been useing them both for a long time,and have tried others, but these two are far and away the best I have found- and they are free!
2helpful
Does my t5274 have tv-out function?
It does not have a TV-out function as it comes from E-Machines, but it does have an open PCI-X expansion slot, so you could buy a video card with TV-out if you wanted to add that feature.
If this helps, please be sure to hit the "thumbs-up" button for me.
If not, use the "add comment" and I'll do my best to help
2answers
Top eMachines Computers & Internet Experts
Andrew Chrostek
Andrew Chrostek
Level 1 Expert
Are you an eMachines Computer and Internet Expert? Answer questions, earn points and help others
