It's possible that the DVD you are trying to play was manufactured for a different region than the one your DVD player is set to. DVD players are designed to play DVDs that are encoded for a specific region or regions. For example, a DVD player that is set to Region 1 will only play DVDs that are encoded for Region 1.
You can check the region code of your DVD player by looking at the back of the player or consulting the user manual. You can also check the region code of the DVD you are trying to play by looking at the back of the DVD case or consulting the information that came with the DVD.
If the region code of your DVD player does not match the region code of the DVD you are trying to play, you will see an error message like the one you described. One solution is to try setting your DVD player to a different region and trying to play the DVD again. However, keep in mind that most DVD players can only be set to a particular region a limited number of times, and once the limit has been reached, the region code can no longer be changed.
It's also worth noting that some DVDs are encoded for multiple regions and will play on any DVD player, regardless of the region code. If you have a DVD that is encoded for multiple regions and it is not playing on your DVD player, there may be another issue at play.
If you know how to access the region code, then I suggest you give it the code for "0" then you will not need to change it again. It should play back all.
Hi there! North American TVs, consoles and DVD players play video and games in the NTSC format (region 1), while Ireland's and most of Europe's play in PAL(region 2). You best bet to be able to watch your dvd set will be to purchase a dvd player that plays multi regions (these will be a bit more expensive) or to order a region 2 dvd player from Ireland or somewhere in Europe that uses region 2. Hope this helps!
