Uniden GMR-325/2 2-Way Radio Walkie Talkie Dual Pack Logo
Posted on Apr 10, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Static The walkie talkie not brodcasting sound correctly. It is very quiet if you call it from the other unit, and goes into static after the call untill you call the other walkie talkie. Everything else seems to work fine. I think it might be a loose wire. I got them at a garage sale, so I do not know what model it is. It is orange and black if that helps, and it has a model RC6488 charger. It has a battery model BP38. How can I fix it?
Anonymous
Level 2:
  • Expert 50 Answers
  • Posted on May 31, 2009
Anonymous
Expert
Level 2:
Answers
50
Questions
0
Helped
20068
Points
102
You are describing an open squelch. If this unit has a squelch control, adjust it until it quietens.
If the battery voltage drops below a certain point, it won't squelch. That could be caused by a battery that needs to be charged or a bad battery that won't charge up correctly.
1helpful
My little tikes red walkie talkies aren't working. One has static, the other is silent. What to I do?
check the batteries. When left on, the batteries will continue to dis- charge (and what kid turns things off?) and eventually ruin the battery.
1helpful
3answers
One of three Uniden GMR3740-3CK constantly recieves static that goes on and off. tried swapping batteries and did not work. rx display goes on. Very annoying. Other 2 radios are fine. Is there a setti
Well, it IS the squelch level. Most radios do not have an adjustment for this. Take the bad one back, you've done all the tests you can. Good job.
1helpful
One walkie talkie has static on every channel
It sounds like your monitor button is stuck and you are hearing the white noise. Try pressing the monitor button on your other radio and see if the noise is the same. If so, your button is stuck. If not...
Sometimes a lot of static can be an indication of a bad or poorly charged battery. To check for this trade batteries with your known good radio and see if it solves the problem.
2answers
Static noise rx
Check your batteries. Static can be a sign of a bad or low battery. Swap batteries between the units to see if the problem moves to another radio.
Also, check your antenna and antenna connection.
Best regards.
Constant static midland walkie talkie
Doesn't it have a squelch adjustment?(it allows you to adjust sensitivity of the "gate" on the receiver).Turn the knob counter-clockwise until it just goes quiet.The receiver will be silent until a transmission is detected.
1helpful
Talkabout T4500 (7 Channels) 2-Way Radio: A Motorola T4500 (small) walkie talkie makes a sta...
One of my T4500 radios does the same thing. When I transmit or the radio is receiving, the interval is interrupted and it takes another 12 seconds to make a popping noise. Weird! I tried to post this as a comment but FixYa kicks out an error so apologies for posting it as a solution!
1helpful
BellSouth 1010 walkie talkie receives constant static
you have opened up the squelch - refer to the manual to close and return radio to normal operation
4helpful
GMRS/FRS static, call button not working, which channel?
Are the radios new or old? Are they likely to be broken?
We need more info to help!!
M3ODQ
3helpful
2answers
Constant RX mode on Cobra Microtalk Walke Talke
I have the same walkie talkies and on mine I can hold down the mode/lock button and it will come off of the Rx mode. Also, you should be able to press the talk button and it will come off of the Rx mode.
Top Uniden Radio Communications Experts
John
John
eradiostore
eradiostore
Grand Canyon Tech
Grand Canyon Tech
Are you an Uniden Radio Communication Expert? Answer questions, earn points and help others
