Question about American Standard Home
What toilet is best.
We would like to find a comfortable, chair height, round bowl toilet at a reasonable price. What brand and model would you suggest?
  • 687 Answers
American Standard Cadet
Posted on Apr 10, 2009
    Habit-Forming:
    Scholar:
  • 35 Answers
If you are looking a good bathroom fitting that ensures a leak-free and consistently comfortable experience,You can consider
"TOTO Ultramax II"
for the modern sanitary solutions.
People would want a toilet that gives them both performance and convenience which seems very difficult to find. But, TOTO Ultramax toilet brings a right solution for your bathrooms. It yields sufficient comfort to the users.
The toilet uses a powerful flushing system which works fine but it does not create any noise or distrubance. Thus, this feature makes the toilet an ideal one and suitable for your office, home, hotels, etc.
The overview phase of "TOTO Ultramax II Toilet review"
will give you specifications of the toilet and will help you understand about the factors, advantages and disadvantages of the toilet and make a choice accordingly.
What toilet is best. - toto-ultramax-ii-toilet-0ol2bzcht5ybnska4h1t4b5r-1-0.jpg
Posted on Mar 17, 2018
SOURCE:
HI NEED A BOWL FOR THIS TOILET? JACUZZI DON'T MFG.OR STOCK ANY LONGER. HAVE ALL OTHER PARTS BRAND NEW.ANY MFG OK.
Amazon.com: Customer Reviews: Jacuzzi EZ33959 ...
www.amazon.com/Jacuzzi...Two.../B0027E6AFG
Amazon.com, Inc.Jacuzzi EZ33959 Perfecta 1.6 GPF Two-Piece Round Comfort Height Toilet with Seat, White ... not unique to this model, but we're not happy using the toilet bowl brush ever other day. ... Two have flush levers (handles) that fall off in your hand.
Nov 24, 2015 | Jacuzzi Home
Which toilet is best?
I replaced the 2nd floor toilet in my house several years ago. It has all the features you require, except the 17" tank width. If you can fit a 20" tank ( actually 19 3/4") then the brand to buy is Toto. The quality is unsurpassed.
The (included) *seat* height is 16 1/8". GPF is 1.6, but the flush is amazingly powerful. I opted for the special self cleaning coating they call "Sana Gloss". Nothing sticks to it, it doesn't stain, and I've never had to use a toilet brush nor bowl cleaner on it the whole time I've owned it.
I bought mine from an online distributor. Just Google "Toto". I haven't checked recently, but they may have a narrow tank model. Mine has the extended bowl.
Apr 15, 2014 | Home
Which is the best toilet?
American standard cadet III is a nice flushing toilet that is reasonably priced. The tank is smaller than the cimarron. Toto also makes good flushing toilets that would fit your needs, but you will pay more for it too.
Apr 15, 2014 | Home
Plunger to fit Kohler bowl
So there is pressure when you push, and suction when you pull. Plungers are more effective when pushing water instead of air because water doesn't compress. ... Thrusting the plunger moves column of water like it was a solid piston and applies the entire force of the thrust against the clog.
Dec 15, 2013 | Kohler Memoirs Classic Comfort Height...
My brand new toilet american standard round front model cadet 3 tank not fill water
If you verify that the water supply to the toilet is turned on, push down the float on the flush valve. Water should start flowing. If it doesn't, something (such as debris) may be blocking the valve and preventing filling. The new valve could be defective - permanently closed.
Jan 11, 2013 | American Standard Cadet 3 Right Height...
My kolher k3497 will not hold water in the bowl. It drops way below the water level.\r\nWhen first flushed it fills correctly but if toilet is not used in four or five days the water level drops way...
It depends on what you mean "not used daily".
I am discounting any possible cracks.
If you only see this after a month or so, the water just evaporates.
If the water level in the bowl drops more often, the different pressure could cause it to exit the normal way. You could try opening and closing a few doors while watching if the water moves at all.
You can have someone flush the 'regular' toilet while you watch the water in the bowl of your guest toilet. There should be no movement at all.
If none of this gives any indications, I guess a plumber might know after inspecting it.
Jun 20, 2011 | Kohler K-3497 Cimarron Comfort Height...
The bowl will not hold water. This is the second toilet we tried because Kohler thought it may be a faulty tank but same problem. Everything works correctly in the tank but after flushing the bowl will...
the tube that goes from the fill valve to the fill tube may not be installed correctly. the water must be going in the tube and not the tank. also it is a water conserving toilet so it uses less water also it is a comfort height toilet and to make it taller the bowl is extended so the water may seem even more shallow.
Jan 18, 2011 | Kohler Highline - Comfort Height Two-Piece...
Toilet running about 2 seconds every few minutes
Tube in cylinder. Water should not come over cylinder, but 1/2" or so below.
Apr 25, 2010 | Kohler Cimarron Comfort Height elongated...
Master bath toilet replaced with a Cimmeron class 6 confort height toilet. The master bath toilet backs up to the hall bath toilet - same wall. The hall toilet is very old. When the old toilet is flushed,...
Kohler is correct. The most likely cause of this problem is an obstruction in the common vent stack that both toilets share. When you flush the old toilet it need more air to flush and will get it from the easiest source (your new water saver toilet). First adjust the float level in the old toilet so it won't use as much water or just stick a brick in the tank to take up space.Second, run a snake down the vent stack from the roof to check for obstructions. Birds will sometimes nest in there.
Mar 16, 2009 | Kohler K-3489 Cimarron Comfort Height...
Home Logo
248 people viewed this question
Top American Standard Home Experts
US Parts Center
US Parts Center
Donni Steen
Mike
Are you an American Standard Home Expert? Answer questions, earn points and help others
