Isn't the vehicle under warranty ? Your best bet , take it to the dealer . They will hook up factory scan tool an find the problem . You won't ! You have no idea how complex the electronics are on your vehicle
I'll try to help, everytime something gets replaced on these yukons, that circuit needs to be RESET ! Is there a reset button, on your steering wheel, to reset a variety of functions ? , check owners manual, or call your dealer for better advise
It is the compressor to the shocks. It hapens when the shock has a leak. It's called air ride system. it's very annoying disconnect the power going to the motor behind the driver rear wheel or fix the air leak
Did you replace the antennea with the EXACT same one,or did you get an aftermarket one ? Did you replace/reinstall the rubber/plasitic gasket that sit's under the base where the antennea mount's on the truck ? If you answered yes to ALL of these question's,then your problem lie's in the cable itself. Be sure that you have the CORRECT one (cable) because where the cable connect's to the antennea there can be no play (looseness) or you WON'T get the proper signal.
Either the unit is bad there is a loose ground or the antenna connections may be loose or corroded. Bring it to an audio repair
shop and have them check it out.
check fluid level if full remove rad cap when car is cold and run while looking at fluid in rad if it is circulating you should see it moving if it does'nt move after car warms up thermostat needs to be replaced also check to see if fan is working properly and check the reputation of your mechanic some are not always honest
