HP LaserJet 2820 Printer Logo
A
Anonymous Posted on Aug 23, 2013
I have hp 2840 colorjet printer it's sowing "59.99 error turn off then on" on Display, my device is not working pls do me fever...... Thanx
5 Related Answers
Anonymous
  • 3 Answers
  • Posted on Jul 04, 2008
SOURCE: 2840 printer 50.1 & 50.2 error dometimes 13.0 error
Thanks CoolDragon. Ifollowed your advice and eventually replaced it.
After trying to pull out and reseat the fuser a few times (I would even get one or two prints out of it each time), I finally ordered another fuser and problem has gone away. I did google and purchasing site searches (pricegrabber, pricewatch, etc) and found a decent priced site, that also gave discount for your returned bad unit (they gave you so many days to return it), otherwise they'd charge your credit card for the extra dsicount they had origanlly given.
Anonymous
  • Posted on Aug 06, 2008
SOURCE: HP LaserJet 2840 Scanner Error
when poering on this HP 2840 it says" Scanner Error 5"
what does it mean? How to get a solution?
Anonymous
  • 3 Answers
  • Posted on Jan 01, 2009
SOURCE: HP Printer Color LaserJet 2840
I Have A HP Laserjet 2820 on power up went through to scanner bulb warming up then made a clicking noise comming from scanner unit it was trying to escape the case. if this is the same as yours the problem is that the scanner unit can't find the home position strip mounted betweent the gray case wide piece right hand side as you look down on scanner unit with lid up & the top of the scanner glass inside the scanner unit to get to it you must remove top section of the scanner unit & cleean underside of scanner glass please E-mail me if you want full instruction.
Anonymous
  • Posted on May 14, 2009
SOURCE: Scanner error 6 for hp color laserjet 2840
After the hp color laserjet has finnished initiallizing it gives me error code 6
Anonymous
  • Posted on Jun 08, 2010
SOURCE: scanner error 03 turn off then on HP PRINTER ALL
SOLUTION FOR SCANNER ERROR 03
Hi can u help me my 2840 laserjet paint error 54.2 ..rotating to mageta
Display Description The device has experienced an internal hardware error.
Carousel rotation error Remedy Turn off the power by using the power switch, wait at least 30 seconds, and then turn on the power and wait for the device to initialize.
Replace the carousel drive motor. If the error persists, replace the DC controller. If the error still persists, inspect or replace the engaging detection flag.
How to reset printer setting
Turn off the HP LaserJet 2840.
Press and hold down the "Enter" and "*" keys on the printer's control panel, and turn the printer back on.
Hold the "Enter" and "*" keys until you see the "Permanent Storage Init" message on the device control panel. Release the two keys to perform the NVRAM initialization. The NVRAM initialization takes just a few seconds, and the "Permanent Storage Init" message remains on the printer's display until the initialization is complete.
Ensure that the "Ready" message on the printer's control panel is visible. You can now connect the printer to your computer and print your documents. If the "Ready" message is not displayed and your printer is still stuck in a loop, turn off the printer and contact HP customer support (see Resources).
  • To reset an HP 2840 from your computer, open the HP Toolbox program, click "Device Settings," click "Service," click "Restore" in the Resets section and then click "OK" to confirm the action and restore the printer to its factory defaults.
1helpful
3answers
Show picture of carousel rotary for hp 2840
Carousel rotation motor error, only professionals can do this activity,, Pl submit the unit in service center,, online support not suggestible..
My hp2840 scanner not working display message : scanner error 3 turn off and on please advice
Scanner Error
  • Turn off the power by using the power switch, wait at least 30 seconds, and then turn on the power and wait for the device to initialize.If the error persists, replace the scanning assembly.
I keep getting a 50.2 fuser error. Turned off
wheb i give the print out, just show error 50.2 fuser error,
pls give me solution what may problems
2helpful
2answers
52 scanner error on HP Color Laserjet 2840
The device has experienced an internal hardware error. Recommended Action
  1. Turn off the power by using the power switch, wait at least 30 seconds, and then turn on the power and wait for the device to initialize.
  2. If the error is still unresolved, contact Hewlett-Packard for technical support to troubleshoot the problem. Call HP for telephone support
1helpful
Is it easy to replace hp colorjet 2840 fusor?
Here is a link to a short animation showing the changing of the fuser:
HP 2840 Fuser Repl
2helpful
HP 2840 "Engine Error"
engine error is the fact the the printer isnt turning, also may have a fault in one of the circuit boards.
k24674
Grand Canyon Tech
Grand Canyon Tech
