I have a Fujitsu Siemens AMILO Li2735 laptop. the screen works but the hinge bracket on the RHS has completely stopped moving and is no longer connected to the plastic casing surrounding the screen. The other hinge is intact and is working fine but I don't want to rely on this as it has all the important connections. Does anyone have any ideas what to do about my broken hinge? Thanks
I would loosen or unscrew the 8? screws that hold the display on, this will loosen it off without everything coming apart, then tilt the screen down, lift the from the bottom of the screen, pry without breaking, take that panel off and see if you can replace or find the part that came out, it maybe screws or another piece. You can probably put it back together if it fell out, then just put the screen plate back on.
SOURCE: Fujitsu-Siemens Amilo A1630 modem trouble
You need the Smart Link 56k Modem Drivers for your Laptop, here's a link for them: http://rapidshare.com/files/137109853/ModemSmartLink56K.zip
SOURCE: Fujitsu Siemens Amilo Pro V2055 laptop power on problem
Check to see if the ram is securely in place. (that will cause a pc to not boot, usually there is a beep code tho)
SOURCE: fujitsu siemens amilo L1300 LAPTOP wont load up
sounds life the start up files have been corupted you may need to reinstall windows. the only thing is it will delete and data you have on the labtop. if you dont mind about that reinstall windows of the reinstalltion cd.
SOURCE: connection to wireless
There is any wireless adapter showing in the control panel.
According to the laptop specs, this laptop did not come with wireless capability. You need to purchase a wireless notebook adapter for it or us it with a network cable.
See the specs on this link:
AMILO-D-1840-FUJITSU-SIEMENS-Laptop-220304">http://www.twenga.co.uk/specs-AMILO-D-1840-FUJITSU-SIEMENS-Laptop-220304
Click on this link or copy and paste the complete link into your browser.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
SOURCE: Fujitsu Siemens Amilo D7850, wireless internet, hi does it have
Tyr pressing Fn and f1 button or the combination or Fn and F2 it will turn the wireless ON on the laptop, then you will be able to see your router or modem's wireless connection and will be able to connect
Let me know if this will help
Regards
