First is this a problem with just one draw? Move to a different draw. lets eliminate the draws and or the by pass tray. Does this happen when using the Document feeder. Place the original on the big glass does it happen then? Secondly have you the correct size paper are you using metric size paper and the machine thinks it is inch size paper. Have to let the copier know what country it is in. Does this happen when you print or when you copy? Check the guides in all the paper draws they have to be snug up against the paper
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
SOURCE: Minolta Dialta d152
It has to be one of two things. 1) The wrong printer driver for the print controller on this model. 2) Possilby, but rarely seen, a bad print controller.
Personnally I would download a new version of the driver off the konica minolta website and then go from there.
SOURCE: Paper Jam in Duplex mode when printing more than 1 sheet
check between the rollers there will be small bits of paper jammed in that is the reason.
SOURCE: Why does minolta copier print white stripes?
TRY TO CLEAN AND CHECK MAIN CHARGER AND TRANSFER CORONA FOR VOLTAGE LEAKAGE,AND CHECK DEVELOPER GEAR AND DEVELOPER DRIVE GEAR
SOURCE: magicolor 2400w won't print on top of page, then jam
I kept digging until I found some helpful, lucky people that stumbled across a solution. The cost of doing the repair yourself is about $1 for superglue.
I detailed the repair in my blog: http://dlburkhart.spaces.live.com/blog/cns!5BA5F950B86A8BE5!182.entry.
I don't know if that URL will work as a permanent link. So, just in case, the same information is on my business web site on the Tech Tips page: http://www.BurkhartTech.com/Tips.html.
I hope to have helped.
If anyone can use a custom web site, I can really use the work. I left work a couple of years ago to be a stay-at-home dad and to try to start up a web site business. Things started out okay. But the economy soured, all of my business dried up, and now I can't find full time employment.
sir/mam Replace the print head the device that houses the machine LASER, or the "J" or "A" printed circuit boards. Go with the LASER first if you can find one the Di520/620 are legacy machines from Minolta now Konica Minolta. Reset is Power off the Power on.
thank you everyone for reply-ing.
@ Oralondo Solomon, i don't think that the software of the printer is the problem... it does the same when copy-ing... Surely it's a problem with the copier it self...
@ Legin Varghese, i looked everywhere and i couldn't find any bits... if that was the problem, i think the outputed paper should have marks on it, like folded corners or stuff like that... my peper is comming ok at output...
@ Fernan, i would do that, but i don't know how... can you be more precise on the operation please? thanks in advice..
@ David Burkhart thank you for your time, but i don't have a problem with folded paper... my printer doesn't start to print where it has to... is printing to "high" and to much at the left... the paper is passing ok throught the machine...
@ deniman couldn't find anythink helpfull... thank anyway..
@ zakor google-it.. i don't have that driver... sry.
