SOURCE: kitchenaid dishwasher, control panel is not
I don't know your technical ability, but there is a fuse located next to the control board inside the console, this is a good place to start. Kitchen Aid is good about putting tech sheets on the back of the kickplate and it should have wiring and diagnostic info there. Just be sure to put the sheets back so the next service tech to work on it will have them :)
SOURCE: I have a KitchenAid Whisper Quiet Dishwasher. Has
I may have leaked water into the mother board ciruitry. This can happen when there is a tiny leak or when steam gets in. Check with kitchenaid, that is a good product and kitchen aid will stand by thier equipment.
SOURCE: KitchenAid dishwasher KUDS25SH - Can't operate because child lock
If holding the "Energy Saver/Dry" button does not solve the control board problem then most probably the control board would have failed and needs to be replaced .
To identify it we need technical expertise in handling the circuit boards and knowledge on usage of multimeter is must.
SOURCE: KitchenAid Dishwasher won't drain KUDI01ILBL6
Do you have an air gap on your sink? Check it to see if its plugged.
