The timer clock has gone and is continuosly flashing. where the reset button should be is just a stud which does not work. pls advise what can be done. the timer clock went off with a power cut and did not return. it is an electric oven make:- prima fcem9 model opr826
To stop the clock area from flashing and for it to display time, the time must be set.
when you program most ovens to start at a certain time, then need to change the setting, use the reset button (not used to set the time) Not very likely you will get much help when you are handing out inappropriate ratings so handily. you can go to whirlpool.com, select the proper international site and download a owners manul
where the reset button should be, there is just a stud which does not function
there is no reset button to use to reset the time. where the reset button is normally found there is just a stud
