SOURCE: range master 50000 exhaust fan stopped working
Extremely likely the fan motor. get to it then , after removing fan blade,plug it in directly to a 110v outlet ,just for a second to see if it works well( don;t touch it while prefoming this test,only the plug), or jumper out the switch(with electric disconnected) momentairly to see if the fan runs after turning the electric back on.
SOURCE: fan blades or motor in Nucor over the stove hood
The FR Series fans from Fantech are glued closed to prevent air leakage. Its better to replace the fan than to try and fix it. The cheapest place to buy a Fantech fan is at http:///www.hvacquick.com as they buy direct from Fantech.
Alos the FR Series fan comes with a 5 Year Manufactures warranty.
SOURCE: Ventline Range Hood Fan broken
In my RV, which should be similar, I removed the filter from the hood. With power off, I removed the fan, which was held on with a clip. Removed two screws holding the motor in and took it to a camper supply store. Mobile home supply would have had it, too. You might find the motor on line if you go to the website of the manufacturer or search for parts for that brand.
SOURCE: range hood blower motor - rangemaster
I'm not sure if it a regular home range hood but if it is. Check the price of a new one. A regular home range hood cost around $100.00 and a fan motor runs around the same. If it a commercial type is another story. If commercial Heritage Food Service Equipment will have the motor.
SOURCE: i have a dayton kitchen exhaust blower mod no.
I have just put in a 4HZ34G ventilator over the grill at the bar and it does not pull enough air to do anything is there anyway that i can do some up grade to this fan from the 8.25 fan and 1/30 hp motor so it pull more cfms
Badge
1.2 amps, 115 volts 60hz
1550 RPM; Shaft 1/4" x 1"
Rotation = CCW
3.3" Diameter Motor
2 Mounting Studs Opposite Shaft End
Motor Case Length 1 15/16"
2-Prong 115 Volt plug
For Model 8663RP, 8673RP
8664RP (86933-000)
86933000, JA2B104N, JA2B104
can substitute 99080517
Part # 86933
$43.95
It's on the first page, and the 8th motor on the page at the time of this post. Hope this helps!
