Need basic instruction on how-to
I just did this today. You have to remove the motor. first start by removing the two hoses then remove the four 1/2 inch bolts that hold the motor/pump assembly. the wires are clippes to a bracket, pry that off removr the whole motor assemly with the bracket by pushing on the tub to manipulate it out. Then remove the three #25 torx screws that hold the pump to motor, remove the pump then route the belt onto the pulley around the inside pump mount put the motor back on the reinstall it the way you took it off. its not that bad (for the first time ever working on a wash machine). I hope you dont have the problem I do, the belt slips in the spin mode - that is probably why the belt failed in the first place I am still trying to find a solution to that. if you just have a failed belt, you will be just fine.
