Quasar VHQ400 VHS VCR Logo
Posted on Apr 09, 2009
Quazar Model VHQ520/VHQ540 cannot record after inst Digital Conv
Cable company just installed digital converter box on TV with VCR.
Now I cannot record program when programming for timed recording.
Connections made are incoming cable (CATV) to Digital converter, Digital converter to VHS, and VHS to TV.
The VHS worked perfectly up until digital box installed.
Wayne from Chattanooga
Anonymous
Level 1:
  • Contributor 22 Answers
  • Posted on Jun 02, 2009
Anonymous
Contributor
Level 1:
Answers
22
Questions
0
Helped
10596
Points
45
You need to set the vcr to channel 3 or 4 (whatever channel the digital converter box is set to broadcast on) to record a program. The digital converter box has to be set to the channel you want to record the show from.
1helpful
I have a vcr/dvd combo. Can't record on it, was told that was because the cable here is digital. Is there some sort of adapter I can attach to enable my vcr to work again?
The only way to get your cable company's digital cable into the VCR is to provide a separate cable TV converter box for it.
This will be "an additional outlet" as far as the cable company is concerned - which means you'll pay extra for it. The other problem will be that you will have to locate the VCR cable converter away from the one used to send a program to the TV. This is because there is a very good chance that when you aim the remote to change the channel on the TV's cable converter - it will also try to change the VCR cable converter box.
If however, you have HD service on your TV you should not get an HD box for the VCR - unless there are stations that only exist on the HD converter box. This is because your VCR (like all the others in the world) are only capable of recording the old, analog "SD" or standard definition video signals. If you decide to go the route of an HD and an SD converter setup, you may not have a problem with one remote controlling both converters. Ask the installer (or test yourself) before setting it all up and merely assuming it will work as you expect.
If you end up with two identical converter boxes, you're going to need to either separate them so that the remote will not operate both at the same time. If this isn't doable, you might consider placing electrical tape or similar to block the remote signals from reaching the the VCR converter, and use the channel up / down controls on the converter box itself to tune instead. Since the VCR will only record what is sent to it - you'll have to make sure the converter box is not only on, but tuned to the correct channel before each time you want to record something. This brings up the last caveat, you'll need to set your VCR channel to match the output of the converter box (usually ch 3 or ch 4) and record only that channel. You could simply connect the converter audio and video output to the VCR's audio and video input instead. If you do this, make sure the VCR is programmed to record only the audio and video input ("A / V") instead of a channel.
This can sound a little complex - and it is to some people, but with a little work and some time, you'll be able to do this fairly easily. I wish there was an easier way to do this - but not yet with cable companies so far. The satellite providers are ahead on this with "multi-room viewing" service. Something to think about the next time your cable company announces a rate hike.
I hope this was helpful and good luck!
3helpful
Hi,can I record digital transmissions on my sony slv-se820g vcr barry
You can record a digital TV signal on a VHS VCR but only in analog format. The digital signal must be input to the VCR by some component which has a yellow composite video output and a white audio output such as a digital cable TV box or satellite receiver. For over-the-air digital TV, either the TV must output analog video or you need a DTV converter box connected to the VCR. Bottom line, the digital signal must be converted to analog for the VCR since VHS VCRs generally are analog recorders.
How do I tape onto a vhs from analog tv with converter box?
There are 2 options-
Option 1
Connect the coax cables in the following order.
1 From the wall to the input of the converter box.
2. From the output of the converter box to the input of the VCR.
3. From the VCR to the TV input.
Here is how you record with this option.
1. Tune the converter box to the channel you wish to record.
2. Turn the channel on the VCR to channel 3 or program the VCR to record channel 3 this will record whatever channel you have your converter box set to at the time of the recording.
Option 2- (will not work on satellite)
1. From the wall to a 2 way splitter (made for digital cable. General rule of thumb with digital cable is gold does not usually mean good.)
2. One output from the splitter to the converter box and the other to the input of the VCR.
3. Connect an Audio Video (RCA (yellow/red/white cable)) from the VCR to the TV input.
4. Select the appropriate input on the TV for the VCR.
Here is how you record with option-
Tune the VCR to the channel you wish to record and push the record button or program the timer to record the channel and time that you wish.
Note- with this option you will only be able to record channels that you would receive without the converter box. Also each time that you split the cable line you loose part of your incoming signal and depending on how you house is set up this option could affect the quality of your digital signals on the converter box.
Have digital TV have 3 yr old sony VHS VCR DVD player combo
A DTV converter box will take digital broadcast signals from the antenna and convert them to a format compatible with the VCR. You will be able to record programs received through the DTV box on your VCR if you could record analog over-the-air programs before the digital changeover. You can use either the RF output or the component output from the DTV box to input to the VCR.
I have an RCA converter box hooked up to an RCA TV and a Sanyo VCR. The TV and VCR are set on Channel 3. The converter box is set on Channel 4 and the TV is also switched to CH 4 when viewing digital...
Basically, you cannot use the coax connections for both the VCR and the RCA converter box. I would hook up the phono/cinch connectors from the VCR to the TV if you can (these are also called RCA connectors, but I'm avoiding using that name so we dont confuse the digital receiver with a cable/connector name that is the same here). There should be a yellow one for video and red/white ones for left and right stereo. I believe the RCA converter comes with a three headed cable that can do this for you. With this configuration, you can set the TV to input on these connectors and the VCR should always output there. Once that is set, you can still use the converter box to receive the signal from your antenna, then run the coax to the VCR. Now, the VCR will always have to be set on channel 4 in your setup and you will need to manually change channels on the converter box for it to record a show. Does this make sense so far?
Connecting tv, converter box, vcr, dvd player
You will need a splitter,
pixel.gif --> #bubwrapper { position:relative; width:98px; height:113px; } #bubLyr1{ position:absolute; visibility:visible; width:0px; height:0px; left:0; top:0; padding:0px; } #bubLyr2{ position:absolute; visibility:visible; width:120px; height:0px; left:35; top:-20; padding:0px; } #bubLyr3{ position:absolute; visibility:visible; width:120px; height:0px; left:-61; top:-32; padding:0px; } #bubLyr4{ position:absolute; visibility:visible; width:120px; height:0px; left:200; top:-20; padding:0px; } #bubLyr5{ position:absolute; visibility:visible; width:120px; height:0px; left:-30; top:-32; padding:0px; } function showCustomPopUp(thisUrl,thisName,theseParams) { remote = open(thisUrl, thisName, theseParams); } function showEnhanced() { remote = open("/largeImage/index.jsp?LargeImageURL=" + escape(document.path.enh.value), "largeImage", "width=505,height=525,left=0,top=0"); } function verifyFields(submitProcess,formObject) { if (submitProcess == "wishlist") { formObject.wlName.value = "wlName"; formObject.submit(); } else { formObject.wlName.value = ""; ajaxAddToCart(formObject); } } function popUp(URL) { day = new Date(); id = day.getTime(); eval("page" + id + " = window.open(URL, '" + id + "', 'toolbar=0,scrollbars=0,location=0,statusbar=0,menubar=0,resizable=0,width=300,height=50,left = 337,top = 284');"); } function submitCompare(thisForm, thisFormField, prodLength) { var prodsToCompArr = thisForm.gridProductIdsToCompare.value.split("_"); var prodList=""; for(var i = 0; i #stsbubwrapper { position:relative; width:98px; height:113px; } #stsbubLyr1{ position:absolute; visibility:visible; width:0px; height:0px; left:0; top:0; padding:0px; } function showMsg(cnt) { var x = cnt; eval("document.getElementById('stsbubLyr0_" + x + " ').style.visibility = \"" + 'visible' + "\""); eval("document.getElementById('stsbubLyr0_" + x + " ').style.display = \"" + 'block' + "\""); } function hideMsg(cnt) { var x = cnt; eval("document.getElementById('stsbubLyr0_" + x + " ').style.visibility = \"" + 'hidden' + "\""); eval("document.getElementById('stsbubLyr0_" + x + " ').style.display = \"" + 'none' + "\""); } pixel.gif $10.99
prs1c-2159957t98.jpg rsk_ourexclusive_icon.gif 2-Way Hybrid Splitter pixel.gif Model: 15-1234 | Catalog #: 15-1234 pixel.gif
Use to divide a signal to feed two TVs or VCRs, or to combine signals for transmission on a single c...
Connect conv box and vcr on the two terminals and the single one to the tv.
Hope this is a Fix Ya!
My Zenith VCR is not working with the digital converter box
When the VCR is "off" the converter signal should go right through the box, which you say it does. Then, when you turn the VCR "on" the picture disappears. That, so far, how it should be. To get your picture back while the VCR is "on" you must set the VCR to "receive" channel 3, and use your new converter box to change channels...accordianman
1helpful
Can I watch tv on 1 channel while recording another?
Unfortunately no, unless you get a second converter box. You're using the converter box to select channels, and it can only be on one channel at a time. With a second converter box, you might find you need a second antenna too (so you can get a signal on both channels). And you can't program your VCR to record on different channels (since it can't control the coverter box to change channels).
(This is a case of history repeating itself. When cable TV was new, and most TV's and VCR's weren't cable-ready, you needed to use the cable company's converter box. The same problems came up then too!)
1helpful
DTV Converter hookup
Is it possible to record TV programming on a VCR when using a DTV converter? h1 = document.getElementById("title").getElementsByTagName("h1")[0];h1.innerHTML = widont(h1.innerHTML); Hi,
I had the same problem and found this answer that worked for me. Hope this does the trick for you.
Simple stated, your VCR must be set to channel 3 also. Check it out.
woody
  1. You must have the VCR tuned to record on channel 3.
  2. You must have the VCR connected to output signal of the DTV converter box. In other words, the converter box must be connected between the antenna and the VCR. So, the likely configuration you would use with a coaxial cable is antenna to DTV converter to VCR to TV.
  3. You must tune the DTV converter to the channel you want to record prior to recording. The VCR won't be able to change channels on the DTV converter.
  4. You will be able to use the timed record function on the VCR but you must adhere to steps 1-3.
If this sounds freakishly familiar to recording on a digital cable or satellite set-top box, you are right. It is exactly like recording a signal from a digital cable box or satellite receiver. While it may be inconvenient to perform the steps above, at least the option still exists to record on a VCR while using a DTV converter box.
Disadvantage of DTV Converter: You will lose the ability to watch one program and record another with the DTV converter. Sorry for the bad news.
The reason is the tuner. The VCR tuner is useless with digital except for recognizing channel 3. The digital converter is a single tuner item so it only receives one station at a time.
3answers
DVD/VCR Combo
your model is "tuner free" that means it does not have the RF screw in connector. Buy one that has a tuner, preferably both ATSC(USA digital) and NTSC(USA analog)
Top Quasar Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
 Grubhead
Grubhead
Are you a Quasar Televison and Video Expert? Answer questions, earn points and help others
