Question about Audiovox CDM8940VW
Cell phone wont turn off
As of carrying it in a thunderstorm, my phone doesnt turn off without taking out the battery. If the battery goes completely dead, it is a challenge to get it to turn on and to make contact with the charger and start charging. I tried a "new" battery and the charge hold time is about the same as my old battery so I suspect it is not new but used. I did not buy it from VERIZON where I got my phone. My phone is AUDIOVOX CDM8940
  • Audiovox Master
  • 14,641 Answers
1.Check the device's battery level for at least two bars of strength.
2.If the battery level is low, charge the battery.
3.If the issue is not resolved, remove the back cover.
4.Remove the battery.
5.Wait 10 seconds.
6.Press and hold the W key.
7.While pressing down the W key, re-insert the battery.
•The device restarts and after approximately 15 seconds, the 'Recovery' screen appears
•Release the power button but *continue holding the home button*, for another 30 seconds.
Step
Thanks
Posted on Jul 09, 2017
SOURCE:
SOURCE: Audiovox CDM8910 Issues
hit star 228
Posted on Sep 21, 2007
SOURCE: phone keeps turning on and off - wont charge
wont turn on.
Posted on Dec 09, 2007
  • 85 Answers
SOURCE: my Audiovox 8910 will not turn on evenafter buying anew battery
This is not likely a battery issue but is indicative of a phone that has gotten wet or has been infected with a virus or has other software issues. We work on cellular phones and would be willing to look at your phone to see if the phone numbers and pictures can be retrieved. Call 1-800-297-5550 and speak with Debby, 9 - 5, M - F, EST for shipping info. You can also contact Audiovox in NY to arrange for out-of-warranty repairs but they will not save your data as a part of the repairs.
Posted on Oct 16, 2009
Sheikhtijani
  • 1284 Answers
SOURCE: bad contact charger
The charging port is bad, so you have to take it to a technician or get a universal or desktop charger to charge you battery.
Posted on Jan 07, 2010
dvdcdlaser
  • 1285 Answers
SOURCE: CAN I USE MY AT&T SIMS CARD IN A VERIZON AUDIOVOX CDM8945VW PH?
if there is a sim card slot on any cell you can use the phone...just one thing might stand in your way (do the starcom say verizon on it...you may need to have this cell unlocked) most carrier do that...but put the sim in now and call your house phone to see if it works or not...
Posted on May 19, 2010
Why wont my phone LG G4 turn on all the way
It won't completely come on because the battery is burnt out I would suggest buying a new phone or a new battery but u will lose everything ether way you do it hope this has helped
Nov 09, 2016 | LG Cell Phones
My phone turned off and now it wont turn back on
Hello, First take the battery out and let set for 30 mins. without and put back in and try to power back up. If that doesn't work then either your charger isn't working, your battery is bad or your phone is bad. You can try replacing the charger or the battery, if that doesnt work will have to be repaired or replace.
Oct 25, 2015 | Cell Phones
My cell phone screen flickers when in a call and wont let me do anything
take out battery and sim card ,put battery back in without sim card turn phone on leave 5mins then take out battery without turning phone off put it back together turn phone on "just needs updated"
Jun 27, 2013 | Cell Phones
My power button doesnt work anymore
Mine turns on when I plug the charger into it. Have you tried that?
Jul 04, 2010 | HTC Hero Smartphone
Well i have a sony ericsson w850i and it wont turn on and when i plug it in to charge it it has this red light on the top on the on/off button it doesnt flash or anything it's just a still red light. Does...
the phone might be completely flat. For you to test for that, you will need to leave it for about an hour or two to see if it will come on.
Then if it doesn't,that means the battery cell is too weak to power up the phone.
You will need replace battery.
Take care.
Jun 16, 2010 | Cell Phones
Charged, wont turn off/on
Try switching off the phone leave it off for some time and then switch it off...
If this doesnt remove the battery and put it back on... and then switch on the cell phone...
This must do the trick...
A small piece of advice mate... Never charge your phone for a whole night... Just put the cell phone for charge for some 2 - 3 hrs or till the batteries are fully charged... Your cell phone's battery would become weak if you charge for a considerably longer duration than required... And i am pretty sure that the problem you got now is joust because of that...
Hope this helped...
Dont forget to vote!!!
Fixya!!!
Oct 18, 2008 | Motorola Mobility RAZR V3
My Sony W580i has begun to shut itself down with no warning. In the middle of a conversation, when it is in my carrying pouch - whenever.... Help?
MY CELL PHONE JUST DOESNT WANT TO TURN ON OR ANYTHING
ITS COMPLETELY DEAD
I EVEN TRIED CHARGING IT
AND IT WONT CHARGE OR DO ANYTHING!!!
BUT WHEN I FIRST TRIED IT WOULDNT
STOP VIBRATING IT WOULD VIBRATE NON STOP
THEN IT JUST STOPPED AND DOESNT WORK FOR ****!
May 15, 2008 | Cell Phones
Wont turn off
First, take the battery out and put it back in to reset it. Then try again to see if you can manually turn it off.
This resets the phone and is the first step in troubleshooting.
Another thing I would do, is test to see if there is something wrong with the end button itself. With a flip phone, normally the end button is unneeded because you close it to hang up. Try ending a call using that button to see if it is a broken keypad issue.
I would also have the local store update the firmware, which should repair any files that may be corrupted, if that is the case.
Also, if the phone has any water damage (when you open the back of the phone, there will be a red dot instead of a white one), this can cause all sorts of crazy problems.
If none of the above solutions work, the only other way to power your phone off is just to remove the battery. You should be able to put the battery back in without the phone restarting, but if it does, just keep the battery out when you want the phone off.
Jan 21, 2008 | Motorola Mobility RAZR V3
Audiovox CDM8940VW Logo
76 people viewed this question
Top Audiovox Cell Phones Experts
Marvin
Marvin
Spud Howell
John Porter
Are you an Audiovox Cell Phone Expert? Answer questions, earn points and help others
