Lucent PARTNER18 Corded Phone Logo
A
Anonymous Posted on Aug 22, 2013
Need to program roll over on lucent partner phone system
5 Related Answers
Anonymous
  • 65 Answers
  • Posted on Feb 17, 2008
SOURCE: Manual
http://www.ez-manuals.com/products.asp?cat=27 This is for a manual for the system. the phone will not operate with out the main system.
A
Anonymous
  • Posted on Jun 30, 2008
SOURCE: Checking voice mail from remote location
If you are using Partner voicemail, you would just press *7 when you hear the voicemail system.
If you press *7, and do not get prompted for the extension number, you dont have a Partner voicemail.
Anonymous
  • Posted on Nov 11, 2008
SOURCE: lost manual to Lucent Partner 18D
Go here http://support.avaya.com/elmodocs2/partner_acs/r7/518457701_2.pdf
Anonymous
  • Posted on May 14, 2009
SOURCE: Merlin Legend (Lucent) phone--changing vm list of extension
Depending home you have it set up, If you list in sub menus and announcement you will go into the auto attendent, then edit. You may also or program them by last name. system admin, press 9 (get you into the system) , administor ext., dial the ext., admin directory listing - this is when you numerically add first or last name. contact me if you need help [email protected]
consultel1
george peters
  • 860 Answers
  • Posted on Sep 27, 2009
SOURCE: ring options
Changing ringing on a Partner system is done on either ext 10 or 11.
At one of those ext's press the feature key and "00"
Next press the left hand intercom twice
Press the right hand intercom once. The display should say Centralized Programming.
Enter in the extension number that you want to program.
Press the line that you want to ring.
A solid light on the line means immediate ringing
A slow flashing light means delayed ringing (meaning the phone will wait 3 rings before starting to ring.)
A fast flashing light means no ringing.
When finished with that station press the right hand intercom and enter in the next extension to program and set ringing accordingly.
Press feature "00" to logout
Our lucent partner phone system has gone crazy! when a calll comes in all of the extnsions ring at once. we also can't access our voicemail- it just rings and rings and doesnt allow us to enter our ext...
I am betting the time and date is wrong as well.
Sounds like your system lost its programming.
call in a professional, they need to reprogram the entire system.
4helpful
We have a Lucent Partner 34D and need to reset the time.
Changing the time on a Partner system is done on either ext 10 or 11. At one of those ext's press the feature key and "00"
next press the left hand intercom twice
the display should say system programming
enter in "#103"
the display should say system time and the current programmed time
enter the new time in 24 hour format
press feature "00" to logout
Lucent Partner phone speed dial
At ext 10 or 11, press feature 00
then feature and 600 or whatever code you want
then enter the number as you would dial it.
when done, enter feature 00 to get out of programming.
12helpful
How to change time on lucent partner 18D and also the incoming message.
enter in "#103"
1helpful
Change Time on Lucent Partner system
enter in "#103"
Lucent partner 18d- reprogramming
go to support/avaya.com and get a manual for free. Try to find out what release is your partner system. Cheers
1helpful
2answers
Need to change the main greeting on our lucent/partner system?
You need to press 0 at the voicemail login prompt. If you dont have a button programmed you can dial Intercom-7-7-7. If the system is configured properly you will get the login prompt. You can then dial 0# for the admin login. The default password is 1234#
AUTO ATTENDANT NOT ANSWERING
There is about three to four programs that need to be set up in your phone system in order to do this , the program number my be a little different depending on the partner system you have .
Ringer for Lucent Partner18D
Are you trying to change if it rings or how it sounds when it rings?
The phone you have (Partner 18D) can be used on several different Avaya phone systems that all program differently. To change when it rings, this would need to done in the system programming (not the phone) All the manuals are avaialble on Avaya's web site but you need to know which system you have before you can start searching. www.avaya.com
Top Lucent Lands Phones Experts
vince
ADMIN Andrew
ADMIN Andrew
Are you a Lucent Lands Phone Expert? Answer questions, earn points and help others
