No sound on some channels, some channels have wrong sound for pic
Channel 2 has channel 4 sound, channel 4 has channel 2 sound. Channel 7 has no sound along with a few other stations. I have Comcast cable line straight to television. Other tvs in house are fine
Do you have an old VCR? because they used to work around this channel. If not forget what I said. If so, try changing the output, or if you don't use it, put it somewhere else.
by reading your problem the main thing is that your tuner of the tv is faulty or it can not tune the specific frequancy of the channel and its audio frequency just replace your tuner card
All the tv channels,work find and have sounds wright?Only channel 2 don't?Is not the tv,it channel 2 have broadcasting problems.U check around ur house the other tv channel 2 have sound?Tries go into the tv menu.Goto Audio Setting,go down to resetting the audio functions,now it going back to the factory setting,if it is the tv,that will help.
I know you can that you can change this by simply hooking up a scan tool for specific year. There are language options accessible for situations like this. Here is a sample of what can be changed using VAG 5052 or equivalent scanners.
Coding
0?xxxxx: Model
1 = Lamborghini
2 = Audi A3 (8P)
3 = Audi A4 (8E)
4 = Audi A4 Cabriolet (8H)
5 = Audi A6 (4B)
6 = Audi TT (8J)
7 = Audi R8 (42)
0x?xxxx: Treble Speaker Monitoring inactive
0 = Front Treble Speaker Monitoring inactive active (NOT Audi A4 Cabriolet)
1 = Front Treble Speaker Monitoring inactive inactive (ONLY Audi A4 Cabriolet)
0xx?xxx: Sound Characteristic
0 = Sound Characteristic linear
1 = Audi A4 (8E)
2 = Audi A6 (4B)
3 = Audi A4 Cabriolet (8H)
4 = Audi TT (8J)
5 = Audi A3 (8P)
9 = Sound System
0xxx?xx: Telephone/Telematic
1 = Telephone not installed (Remote Feed Voltage for Microphone active)
2 = Base Plate (Temic - Remote Feed Voltage for Microphone inactive)
3 = Base Plate (Cullmann - Remote Feed Voltage for Microphone inactive)
4 = Base Plate (Nokia - Remote Feed Voltage for Microphone inactive)
5 = Telematic Europa (Remote Feed Voltage for Microphone inactive)
6 = Telematic US (Remote Feed Voltage for Microphone inactive)
7 = Base Plate diagnostic capable with Comfort Control
0xxxx?x: Equipment I
1 = Tuner not installed
2 = Digital-Radio installed
3 = Satellite-Radio installed
4 = Satellite and Digital-Radio installed
5 = Analog Input (AUX) installed
7 = Satellite-Radio & Analog Input (AUX) installed
0xxxxx?: Equipment II
1 = TV-Tuner/CD-Changer/Multi-Function Steering Wheel not installed
2 = TV-Tuner installed
3 = CD-Changer installed
4 = TV-Tuner and CD-Changer installed
5 = Multi-Function Steering Wheel installed
6 = TV-Tuner and Multi-Function Steering Wheel installed
7 = CD-Changer and Multi-Function Steering Wheel installed
8 = TV-Tuner and CD-Changer and Multi-Function Steering Wheel installed
Adaptation Channel 001: Tire Circumference
The tire circumference is beeing adapted in "mm".
Channel 002: Wheel Pulse The wheel pulse describes the amount of wheel pulses per revolution. If value 0 is entered the system calibrates automatically itself after several kilometers and inputs a value.
43 = Audi A3 (8P) / Audi TT (8J)
45 = Audi A4 (8E)
Channel 003: Language (Screen)
0 = German
1 = English (UK)
2 = French
3 = Italian
5 = Spanish
6 = Portuguese
7 = English (UK)
Channel 004: Back-Up Camera
0 = Back-Up Camera not installed
2 = Back-Up Camera installed
Channel 005: Speed Threshold (Video Input)
0 = max. 0 kph or 0 mph
1 = max 5 kph (Standard for Europe)
Channel 007: Options Channel 008: Volume Characteristic Channel 010: Region
0 = Europe/North America
1 = Australia/South America
2 = South Africa
Channel 011: Language (Speech Recognition)
0 = German
1 = English
2 = French
3 = Italian
5 = Spanish
Channel 018: Start Screen The start screen setting has to correspond with the control
module coding, e.g. a S3 start screen doesn't work with an A4 coding.
0 = Standard Start Screen
1 = Audi S3 Start Screen
2 = Audi S4 Start Screen
3 = Audi RS4 Start Screen
4 = Audi TT Start Screen
5 = Audi R8 Start Screen
Channel 065: Read Test Channel 066: Self Test Channel 067: CD/DVD Drive
I haven't ever used this program but it sounds like you have your MIDI channel assigned to the wrong number. The default MIDI channel for drums is channel 10. Assign the track you are trying to play drums from to channel 10 in your program.
once a signal falls below a certain threshold the color will be lost. some sets are more sensitive to this loss. if you see static in the picture on any of the channels then the cable is leaking and needs replaced /tightened. if a local air broadcast is leaking into a same cable channel on the cable you will get poor to no reception on that channel. for example : he we have a local channel 7 on the air. if i tune to cable 7 and see a weak or distorted pic then the cable is leaking and needs replaced.
these are FRS radios, and use only the 14 FRS channels within the GMRS band. they will not operate on the other GMRS channels in the GMRS band.
FRS Channel Frequency Assignments:
Channel 1: 462.5625mhz
Channel 2: 462.5875mhz
Channel 3: 462.6125mhz
Channel 4: 462.6375mhz
Channel 5: 462.6625mhz
Channel 6: 462.6875mhz
Channel 7: 462.7125mhz
Channel 8: 467.5625mhz
Channel 9: 467.5875mhz
Channel 10: 467.6125mhz
Channel 11: 467.6375mhz
Channel 12: 467.6625mhz
Channel 13: 467.6875mhz
Channel 14: 467.7125mhz
when you say flickering??? are you saying the screen goes black and comes back on?? does the sound go out at the same time and comes bag on with the pic ? Is the sound there when this happens but is distorted. Is the pic blacked out or is it greying out with lines and twisting?? Need more info please as if its blacking out and the sound goes with it it may be going into shutdown. If the pic is getting kinda greyish with it twisting and the sound is there and ditorted then the tuner could be bad
