I had a problem recently when I looked online to find the manual for this model and a similar model, and thankfully I was able to solve the mystery and locate it. Even though the answering machine says it is a Lucent AS40, the correct user manual for it is the manual for the AT&T 1715. Once I figured this out, it was super easy to locate the manual on AT&T’s website... and sure enough, these two products are identical!!!
The user manual for the AS40 can be found at http://telephones.att.com/docMgt/public/art/161/1715_manual.pdf
I figured this out when I ran across an old article discussing a joint venture between Lucent Technologies (AT&T) and Philips Electronics. Apparently the two companies decided to merge together and combine their resources to develop technologically advanced answering machines. After the products were developed, each company marketed them under their name with a different model number, but both were selling the same thing! The reason we couldn’t find the user manual for the Philips model is because Lucent (AT&T) has the manuals!
In case this might help someone, I own two of these answering machines and can vouch that the user manual for the Lucent AS40 is the same as the AT&T 1715 and the Philips AD2735 is the same as the AT&T 1725. Here are the models that were produced during the joint venture:
AT&T/ Lucent 1715 = Lucent/ AT&T AS40
AT&T/ Lucent 1725 = Philips AD2735
AT&T/ Lucent 1717 = ?
AT&T/ Lucent 1815 = ?
AT&T/ Lucent 1825 = ?
AT&T/ Lucent 7625 = ?
AT&T/ Lucent 7630 = ?
I have the same problem with the FO flashing and want to fix it long enough to play the messages .. please tell me what to do .. the ATT site does not return anything when I ask for the 1715 manual ..
I need an owner's manual for an AT&T (or Lucent Technologies) answering machine.
[email protected]
We have a Lucent AS40 Digital Answering System that has worked quite nicely for several years but now has gone to blinking in a square pattern. and the only button that works is the volume button.
We would like to reset the device and reprogram it.
Help!
