Polycom VSX 7000 Video Conference Logo
Posted on Jan 18, 2018
Just bought a VSX 7000e, refurbished. After connecting all cables per manual, when I turned on unit, no image appeared on monitor. I'm using S Video connector to a 40" screen. Checked all connections and they are fine. Does anybody know if there are other measures I must take to get this operating?
1 Related Answer
Danny Nagdev
  • 47 Answers
  • Posted on Apr 08, 2008
SOURCE: VSX 7000A connects domestically but cannot connect internationally
Please check with your Internet Service provider. They might have a firewall which blocks the ports used for video conferencing
Can I use a Pioneer Elite VSX- LX101and a Bose Acoustmass 9 powerized speaker system.
You are only given one answer from our Expert Ray with the brief answer 'No sorry'.
This is your VSX
REAR TERMINALS
HDMI 4 in
HDMI 1 out
AV (Composite) 2 in
Audio 1 in (assignable)
Digital Coaxial 1 in (assignable)
Digital Optical 1 in (assignable)
Monitor Composite 1 out
Preout 0.1ch (SW)
Speaker 5 ch out (FRONT, CENTER,
SURROUND)
and this is your Bose. Find the manuals for both and read them. connecting them
https://www.techwalla.com/articles/bose-acoustimass-9-speaker-system-installation
A: Glancing at the specifications of the Bose Acoustimass 10, the system is stated to be compatible with A/V receivers and amplifiers rated from 10-200 watts per channel, and from 4 ohms to 8 ohms. Aug 17, 2014
Q&A: I Have A Bose Acoustimass 10 System, What Receiver ...
It is a pity you don't have a newer one that can be connected via HDMI lead.
My monitor says :"No signal" What is the problem?
To help you troubleshoot the monitor 'No Signal' issue, please find the steps given below:
- Turn off your computer.
- Unplug the cable running from your monitor to your PC and plug it back in, making sure the connection is firm. The most common cause of this error is a loose cable.
- Re-attach the cable running from your monitor to your PC. If the monitor is still not displaying a signal after firmly reattaching the cable, the problem could lie with the cable, especially if the cable has visible damage.
- Replace your monitor with another monitor if possible. If the 'No Signal' error still appears, the problem does not rest with the cables or the monitor, but with your PC.
- Open your PC case and locate your video card. Remove the card and then replace it firmly in its slot or, if possible, insert the video card into another slot on your motherboard. A video card that is not making a firm connection will not display images to the monitor. Close your PC case and test the monitor again.
- Replace your video card completely. Your video card may suffer from internal damage that is not allowing it to output a signal.
If issue persists, it is recommended to contact your monitor manufacturer for further assistance.
GuruAid.com
Blue screen
Pls check the output mode of the VSX 7000
I have a Pioneer VSX-D308 reciever and I have... no idea how to hook it up to my big TV (bought receiver used). Do I need the red/white cords? Do I need other cables? HELP! Wanting to hook up to big...
What your unidentified TV >>requires<< is the BEST Video from every video source. That would be the DVD, SAT Box. It probably has multiple high-end video inputs, right?
What your receiver needs is at least a basic composite video connection to the TV so you can set it up and manage it.
A web search for "Pioneer VSX-D308 manual" will find the manual.
ALL of the BEST Audio should go directly to the Pioneer. That includes the SAT and DVD player.
Your TV can exist just fine with basic audio from the video sources. And you could still watch it/them without the Pioneer turned of if you want.
I can't find the exact manual for free anywhere but if you download something similar like http://www.retrevo.com/support/Pioneer-VSX-D409-Receivers-manual/id/385ci977/t/2/ it should give you the basic guidance you need.
I recommend
Do some web searching for what the cables are for. It's all basic and standard.
2helpful
During conferencing, I am unable to view myself on the small window that assists in monitoring myself. what could wrong?
make sure unit is set for PIP (picture inside picture) and not POP (picture ouside of picture)
control panel- general - screen settings
Monitor goes black after a moment
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further and it will help out other people in the future also.
http://www.badcaps.net
http://en.wikipedia.org/wiki/Capacitor_plague
1helpful
My monitor screen is ok for awhile but suddenly turns a dull yellow color. I just bought it a few months ago.
you must adjust the display settings in the software program that was being used to change the display setting.
  • If you have a flat panel LCD monitor, unplug the monitor power cable, wait about 30 seconds, reconnect the cable and then turn on the monitor. This resets the electronics on the monitor.
  • Make sure the monitor has power - the light on the monitor is on. If the light on the monitor is off, the monitor does not have power. Connect it to a different power outlet.
  • If the monitor has a detachable video cable, obtain a second monitor cable for testing purposes in case the cable is bad.
  • follw the another steps-
  • Replace the monitor power cable.
    1. Turn on the monitor. If the monitor displays an image, you are done. If the monitor remains blank, continue using these steps.
    2. Replace the video cable. Turn on the monitor. If the monitor displays an image, you are done. If the monitor remains blank, continue using these steps.
    3. If the monitor does not work after replacing the cables, replace or service the monitor
  • Thanks,
    8helpful
    2answers
    Pioneer vsx-819H: MCACC setup won't display on tv
    I would say check the cable version not everyone knows this but there are different version HDMI cables such as 1.0,1.1,1.2 and the newest 1.3 cable these are band-with depended cables and if you use a lower version this should work if not you might have a issue with video.
    Other then that you might have a issue with the unit if all other signals are working on the monitor.. Ruling out this will be hard if you do not have another monitor to test it on. I would be conducting a test on other output monitors and see if you get any results.
    please press the accept button as I worked hard to answer you question.
    Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/edwy_1a56970cf1ea4620
    Get ''not supported ''message on vx-1018-ah
    Verify this is a Pioneer VSX-1018AH.
    The manual explains it all... The problem is probably an incompatible setting on your source.
    Search for "not support" in the manual...
    http://www.pioneerelectronics.com/PUSA/Unassigned+Content/VSX-1018AH-K+OPERATING+INSTRUCTIONS
    I think this may do it... From Page 86...
    No picture or sound. • This receiver is HDCP-compatible. Check that the components you are connecting are also HDCPcompatible.
    If they are not, please connect them using the component or composite video jacks.
    • Depending on the connected source component, it’s possible that it will not work with this receiver
    (even if it is HDCP-compatible). In this case, connect using the component or composite video jacks
    between source and receiver.
    • If the problem still persists when connecting your HDMI component directly to your monitor,
    please consult the component or monitor manual or contact the manufacturer for support.
    • If video images do not appear on your TV or flat panel TV, try adjusting the resolution, DeepColor
    or other setting for your component.
    If ‘NOT SUPPORT’ appears in the receiver’s display, try adjusting the resolution, DeepColor or
    • While analog video signals are being output over HDMI, use a separate connection for audio
    output.
    • When this receiver reproduces MULTI CH IN audio sources with the HDMI setting set to
    THROUGH, you cannot hear audio output from all channels. In this case, make a digital or analog
    audio connection.
    • To output signals in DeepColor, use an HDMI cable (high speed HDMI cable) to connect this
    receiver to a component or TV with the DeepColor feature.
    Check the HDMI Control (Page 65-66 of the manual). It only works with Pioneer Flat Panel TV's. Also check Page 83 for "No image is output..."
    No image is output when an
    input is selected.
    • Check the video connections of the source component (see page 18).
    For high-definition video (using component video connections), or when digital video conversion
    is switched off (in Setting the Video options on page 72), you must connect your TV to this receiver
    using the same type of video cable as you used to connect your video component.
    • Make sure the input assignment is correct for components connected using component or HDMI
    cables (see The Input Setup menu on page 67).
    • Check the video output settings of the source component.
    • Check that the video input you selected on your TV is correct.
    Some components (such as video game units) have resolutions that may not be converted. If
    adjusting this receiver’s Resolution setting (in Setting the Video options on page 72) and/or the
    resolution settings on your component or display doesn’t work, try switching Digital Video
    Conversion (in Setting the Video options on page 72) OFF
    I'd like to know where the vcr cable & cable wire from wall
    (I own 2 VSX-D903S Units.)
    There are NO optical (Toslink) or coaxial connections for Satellite or Cable-TV on this Pioneer unit.
    The coaxial connector on the receiver is for connection to an external antenna for FM Tuner (radio) reception only.
    Your cable line from the wall would go to your Cable Box, or a "cable-ready" TV or VCR. You would then connect the composite (YLR) or S-video output A/V (S+LR) connection to the VCR 1 input on the back of the receiver. Connect your TV L/R audio and S-video or Composite video output to the TV in connection on the Receiver. (Connect the Composite TV-out connection to a composite video-in connection on the TV.)
    Top Polycom Lands Phones Experts
    k24674
    Are you a Polycom Lands Phone Expert? Answer questions, earn points and help others
