2000 Dodge Durango Logo
Posted on Apr 09, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Can a alternator PULLEY make a chirping noise?
I have a 2000 Dodge Durango SLT (5.9L) and it is still making a chirping noise that is very annoying. I just installed a new serpentine belt tensioner & a new belt. It stopped for a day but is back. Also during this annoying encounter, on a cold start before I replaced the above mentioned parts it would stall in the parking position. But after I replaced these parts it doesn't do that no more. Could the alternator be going out? Please help!
  • Anonymous Mar 24, 2014
    Replaced alternator, tensioner, belt, water pump and still makes noise
Anonymous
Level 2:
Sniper:
  • Expert 69 Answers
  • Posted on Apr 09, 2009
Anonymous
Expert
Level 2:
Sniper:
Answers
69
Questions
Helped
62324
Points
323
It's possible that the alternator is making the chirp noise (bearing) but I would try this first. Start the engine and allow the engine to idle and open the hood and take a spray can of WD40 and shoot a short burst onto the bottom side of the belt and pulley. Dont spray allot as this will cause the belt to slip. The WD40 is to lube the pulley grooves and belt a slight bit. Hope this works!
Lefty64
Anonymous
Level 1:
  • Contributor 1 Answer
  • Posted on Jul 09, 2009
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
2363
Points
I have the same problem now, when my brother poured water on belt it stopped. of course it dries and it starts again so maybe the wd40 would be a good solution
Anonymous
Level 1:
New Friend:
  • Posted on Jan 20, 2010
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
2363
Points
I have a 1997 oldmobile 88 it keeps making this chirping noise. They told me it was the altenator, so I changed it. It was fine for a day but now its back. The serpentine belt was changes and pulley what do I do next? Please help!
1helpful
Making a chirping noise while driving
Most chirping noises are due to bad pulleys on the motor. It's usuually an idler pulley or belt tensioner pulley. May also be the bearing in the alternator. Use a stethescope to check otherwise you can use a rubber hose. Put hose up to one ear and put other end by each pulley. Should hear high pitch chirping.
2helpful
Location of air pollin dust filter on a 2000 dodge durango slt?
The dodge Durango does not have a cabin air filter (pollen/dust filter) The only Dodge to have an dealer option to include one is the Dodge Caravan
1helpful
I have a 2000 Dodge Durango 5.9l V8 SLT which I have had since new. Recently My battery drained and ended up replacing the battery, and the same problen occured again so I replaced the battery again. I...
Have you checked the automatic tensioner? It sounds like your belt may be slipping, causing the alternator to not charge the battery as quickly as it needs to, which puts a lot of strain on a battery.
I would have the automatic tensioner checked and replaced, and install a new belt.
I’m happy to help further over the phone at https://www.6ya.com/expert/jeremy_69f3cc28d95bf514
3helpful
4answers
1999 dodge durango 5.9 v8 loud squealing noise from under hood replaced tenison pulley, idler pulley, ac pulley/clutch assembley,and belt please help
You didn't mention the alternator, power steering pump, or water pump. In fact, any pulley other than the crankshaft one can have a bad bearing or dry seal. Remove the belt and spin each pulley while listening for any rough noise or squeal. If it was the crankshaft, it might be time to check the oil. Start the engine with the belt off to see if it does squeal. Make sure the noise isn't coming from the radiator fan(s).
5helpful
3answers
200 Dodge Durango Clutch Fan
The fan shroud needs to be removed. I think there is a clip where you can seperate the bottom portion of the fan shroud to the top. Once the shroud has been removed everything is a piece of cake.
Glove compartment door on my 2000 Dodge Durango SLT won't open
What models of dodge are interchangeable with a 2000 Dakota glove door latch?
Chirping, squealing noise from pulleys
check your pulleys. but if you have a Dayco belt on your truck, sometimes they're noisy. Its just the design. But they're good belts. But I would check the pulley on your water pump first, just in case of bearing wear. That's the best way to start.
4helpful
2answers
2000 Dodge Durango new fan belt making some funny noises...
were the fan is located it is attached to the water pump .the pump is probably binding up move the fan front to back see it the whole pulley moves.
Top Dodge Experts
ZJ Limited
ZJ Limited
Ronny Bennett Sr.
Ronny Bennett Sr.
Thomas Perkins
Thomas Perkins
Are you a Dodge Expert? Answer questions, earn points and help others
