Hotpoint Belt Drum Drive for VTD00, VTD20, VTD60 Tumble Dryers Logo
A
Anonymous Posted on Aug 21, 2013
Need wirein diagram for hotpoint tcm580 - Hotpoint Belt Drum Drive for VTD00, VTD20, VTD60 Tumble Dryers
Does anyone have a wiring diagram or photograph of a Hotpoint TCM580 Aquarius mains connections inside?
There is usually a wiring diagram on the inside of the top panel or rear panel. Sorry but I don't have any diagrams for these.
Where will I find the heat reset button on my tcm580 condenser dryer
Hello Mandy, I am not sure what you mean by a heat reset button; perhaps explaining what the problem is, I may be able to assist you. Are you referring to the dryer motor's overload reset button? As a safety feature, a dryer has a high-limit thermostat and either a thermal fuse or thermal cut-off fuse.
In the event of poor air flow where there is no proper ventilation to the heating element- the internal temperature of the dryer exceeds its high-limit, the dryer will shut-down; once it cools off, you should be able to run it again.
However, if the thermal fuse (located on the blower housing) or the thermal cut-off fuse (located on the heater housing) goes, the dryer heating element will will not heat up or the dryer will stop running altogether.
Please note, a dryer will have either a thermal fuse OR a thermal cut-off fuse, but not both.
By-the-way, there has been a recall on certain models of HotPoint Creda, and Indesit tumble dryers due to a fire hazard risk; I am sending you the link...If your dryer is manufactured by HotPoint model TCM580, then your dryer maybe affected. Read the info in the link- it'll give you instructions on how to determine if your specific dryer is affected and what to do.
http://www.which.co.uk/news/2015/12/113-hotpoint-indesit-and-creda-tumble-dryer-models-pose-fire-risk-426557
http://www.itv.com/news/2016-04-18/hotpoint-dryer-fire-risk-which-models-are-affected
Feb 15, 2017 • Dryers
Hot point dryer tcm580 stoped condensing
hi is condesor nice and clean allso duct in dryer
Tumble dryer not heating up
hi first thing to check is thermostat on heater normaly the one on left
2helpful
Need to change push button on off switch for a hotpoint wm52
there should be a wiring diagram inside the machine if you are unable to find the goto searsappliance parts online and they should have a wirein diagram for you
I have takend the weiring off of my 125 yamaha dt what wires do i need just to start the bike
alrite mate i had the same problem if you go to www.dtr125.net there is a wirein diagram on there
Top Hotpoint Dryers Experts
ZJ Limited
ZJ Limited
Kolbrun...
Are you a Hotpoint Dryer Expert? Answer questions, earn points and help others
