I just had the same trouble in a 02 mazda millennia. found the SHORT.it was in the wiring of the drivers sun visor lights. no kidding, too simple. I hope yours is as easy to fix,,
The fuse is doing its job. There is a surge of power going down the line from somewhere. Have you added anything to your car? Was you turning anything on or off when it happen.?
SOURCE: Keyless Entry and Remote
I have had this problem take you drivers door put your key and un-lock from the out side with key (NO) then open the door push un-lock from the inside button and then set from you remote and it should set if not push un-lock then lock and then do the un-lock with the key. Let me know if that works. what my car did was locked from the inside and I had the problem were it would not work till I un-locked from the out side plus I had to go to radio shack and change the battery from the control.
Hope good happens.
Nikki2913
SOURCE: 2006 Dodge ram 2500 diesel Quad, door locks
Try checking under hood in power distribution box for blown fuses also, or bad connection to it.
SOURCE: Blown Fuse / Electrical problem??
There is a short curcuit in the circuit that fuse protects. Is the radio original equipment or is it an aftermarket radio that has been replaced before? If it has been "worked on" by anyone lately or is not OEM, I would concentrate some there 1st to find the wire being "grounded or shorted". Also, check the door switches to see if they are loose or causing a wire to short against the door jamb. If you can't find the cause of the short, take it to an ASE certified electrical specialist, they will know how to diagnose and repair it. Electrical problems are extremely difficult to diagnose without seeing the car and therefore the price to fix the problem would be difficult to predict as well. But a specialist would likely find the problem in the least amount of time, and though their rates may be higher/hour, the outcome may still be quite a bit lower because they will find the problem faster due to their higher competence. Best wishes!
SOURCE: 2003 ford escape, fuse keeps blowing for door locks, radio and dome light. y
check for a shorted to ground positive wire repair as nesseacry
SOURCE: 2000 vw beetle the pwr windows, pwr trunk, pwr
The easy part of this problem is knowing what it is, the difficult part is finding where it's shorting out. With the meters of wire and harness it would be discouraging thinking about it. Knowing VW took a lot of time engineering to avoid this simple problems, there are conditions that couldn't prevent this.
First off, have you recently installed an aftermarket part that hooks up to the wiring system e.g. radio, gauges, gps or other electronic accessory? Something added that needed a harness moved to make it fit or needed splicing a wire to power it up?
There are times when doing electrical work, the person doing it doesn't realize while stripping insulation from new wire that a strand of wire fell in a switch, fuse terminal causing a short in it's circuit.
You'd need to clean the fuse area with a clean paint brush to dust off any metal debris. Another way is by simply using a digital VOM with continuity tone to single out which component is causing it to blow the fuse.
Another suggestion is use a VAG 1552 scan tool or equivalent. This will also help pinpoint which component to look at and narrow the search area.
If you're a DIY kind of person and want to know how your vehicle works, wanting to get a little more involved. You'll need a Windows based laptop and purchase a ROSS-Tech software by clicking on the address.
