My 50 inch AKAI PT50DL24X/SMS will turn on for about 20 seconds then turn off. When it turns off the power button will flash, timer, lamp, and standby. can some one help me.
My 50 inch AKAI PT50DL24X/SMS will turn on for about 20 seconds then turn off. When it turns off the power button will flashMy 50 inch AKAI PT50DL24X/SMS will turn on for about 20 seconds then turn off. When it turns off the power button will flash
You can't post conmments that contain an email address.
i have one of these akai 27 inch with dvd, i had a similar issue i found a power supply at auction and exchanged it and it works fine now, normally with this symptom your power supply is fualty. if the light goes green and you have no picture then you know other boards are fualty
the popping sound is generated in the audio output amplifier IC, change out the ic and any associated electrolytic capacitors this should restore normal operation good luck
hey there is sounds like your tv is trying to tell you to replace the lamp the lamp is running out of mercury gas and is starting do give up I recommend you get a new bulb
