SOURCE: i can't get my zhu
Not step by step instructions, but this may help. The image on the box is not correct. It is a mirror image, so using the box as a guide is only going to confuse you. The one sheet instructions on the inside are correct. For a "correct" color example, I'll attempt to attach a mirror image of the box. It also helps to look on the picture/instructions for where the track actually breaks and use the sign holes/support holes to help you identify which piece of track to use and how to orient it. (As for attaching track - pay attention to the instructions - linking at the top first is very important.) I hope this helps.
SOURCE: Bought a KB classics build
i have the same exact problem, tried to put the gears back together myself and couldn't figure it out. i tried to see if i could just order another car car but no luck with that either. please let me know, as well
SOURCE: Bought a K B classics build & load track set.
Did you ever figure it out? we just did the same thing
SOURCE: im looking for the manual for item number 220438,
You can get the manual on the links below. email: [email protected]
http://www.kidkraft.com/_media/assembly-instructions/17850.pdf
http://www.kidkraft.com/_media/assembly-instructions/17945.pdf
If that is not it please look at this link below.
http://www.kidkraft.com/toys-and-playsets/trains?page=1
Or call
tel: (800) 933-0771
fax: (877) 933-0771
M-F, 8:30am to 5:00pm cst
