Http://www.amazon.com/HP-P2015-2015-Roller-Maintenance/dp/B00965WQYI/ref=sr_1_1?s=electronics&ie=UTF8&qid=1377471140&sr=1-1&keywords=rk-p2015Hello,
It sounds like the pickup roller is not getting a good grab on the paper. When this happens the roller can not push the paper up into the printer where the next rollers can grab it. this is a very common issue after a year or two of use. The pickup rollers and separation pads come in a kit that is available on Amazon here: http://www.amazon.com/HP-P2015-2015-Roller-Maintenance/dp/B00965WQYI/ref=sr_1_1?s=electronics&ie=UTF8&qid=1377471140&sr=1-1&keywords=rk-p2015
SOURCE: Paper Jam HP LaserJet 1020
Papper never realy "jams" the problene is usualy that the paper is late reaching the next paper sensor. What i would sugest is that you clean the paper pickup roller it is usualy in the shape of a D. Clean it with dishwassing soap dont use water just clean soap rub it on with a clean cloth until the roller is dry so use a small amount. This should solve your prbleme.
SOURCE: laserjet 4345 mfp paper jam
13.20.00 can be also caused be a jam near the fuser (the part of the printer that gets hot to make the toner stick to the paper). Remove the toner cartridge and take a look for small scraps of paper along the whole path. Also open the door on the back of the printer and look for paper scraps from there. If you see paper stuck in the fuser, do not use anything sharp to remove it, be careful not to scratch the surfaces.
SOURCE: 13.01.00 paper jam tray 2
The pickup rollers are worn out. Replace them and your problem will be gone. While you are sourcing them, use some alcohol. This may give them a little more life.
Jams in tray 2
Table 7-10 Causes of tray 2 jams
Cause Solution
The feed or separation rollers are dirty, worn, or damaged. Clean the rollers. If they are dirty after cleaning, or if they are
worn or damaged, replace the rollers.
The pickup roller is worn or damaged. Replace the pickup roller.
The tray 2 paper pickup assembly drive gears are damaged
or the assembly is defective.
Check the drive gears in the paper pickup drive assembly.
Replace the pickup drive assembly if the gears are
damaged. See Paper-pickup drive assembly.
The tray 2 pickup solenoid (SL101) is damaged. 1 Disconnect the connector for the tray pickup solenoid
from the dc controller PCA (location J92).
2 Measure the resistance between the cable connectors.
3 If the measured resistance is not approximately
160 ohms for the HP LaserJet 4200/4300, or 110 ohms
for the HP LaserJet 4250/4350, replace the tray 2
pickup solenoid.
The tray 2 lifter-drive assembly or the stack position
sensor (PS107) is defective.
Replace the lifter-drive assembly. See Tray 2 lifter-drive
assembly and/or Printer switches and sensors.
The dc controller PCA is defective. Replace the dc controller PCA. See Dc controller PCA.
Dirty, worn, or deformed pick-up roller, cassette separation
roller, and cassette feed roller.
Clean the rollers if they are dirty. Replace any worn or
deformed rollers. The cassette separation roller and the
cassette feed rollare are to be replaced together.
Damaged gears in the cassette pick-up drive unit. Move the gears in the cassette pick up drive unit. If the
gears are not rotating correctly, or are damaged or worn,
replace the cassette pick-up drive unit.
