Need the resistor value for the bamf 5500 power acoustic amp r81 and r82 resistors
SOURCE: need resistor value for RK62 on DP2X board for 57SWX20B
RK62 is a 2.2ohm 1 watt metal oxide resistor hitachi part number 0700054M any 2.2ohm 1 watt resistor will work although it does have to be metal oxide(flame resistant) for safety purposes.
SOURCE: jvc subwoofer will not power up
this is not a response to your inquirey but i'll say this if the parts you are looking at are so bad then remove them individually and take them to a electronics center and have them tested.from what i know about this stuff the board may be shot. usually cheaper to replace the board than parts. test the speaker on home amp, or car amp, as deemed appropriate to see if it is good then it becomes a problem of input. good luck
SOURCE: HP Scanjet 5370C circuit board resistor 105 burned..what is size?
http://en.wikipedia.org/wiki/Resistor
I need the same, but found a Makita multi-voltage charger and have been able to use it. The package says It is for Makita batteries only. HItachi also makes a universal battery charger. I found both at my local Lowe's. The Makita was originally $69, but was marked down to $25. The Hitachi was around $70. You can find either one for good prices on Ebay or Amazon.
SOURCE: Schematic (or just R10) for Rampage AMP522A Car Audio Amplifier
2 years later... I just picked one of these up at a yard sale... R10 is actually a diode. The code is buried, but ends in N1.
Hope this helps!
