Quad 47 cc / 49 cc Pocket Mini Bike Scooter  Atv Pull Start Logo
Anonymous Posted on Aug 21, 2013
I pull start my 49 cc pocket bike and it starts. I lift the back tire off the ground and give some gas its fine. but when i sit on it and give it gas it dies out?
Silas Lawrence
Level 3:
  • Master 906 Answers
  • Posted on Jan 25, 2015
Silas Lawrence
Master
Level 3:
Answers
906
Questions
Helped
181628
Points
2158
You most likely have oil spilled on the clutch. OR, the carb needs to be opened by 1/4 of a turn on the set screw on the carb.
5 Related Answers
Anonymous
  • 104 Answers
  • Posted on Sep 06, 2009
SOURCE: pocket bike prblems
Get some engine starting fluid and spray a small amount in the air intake. If that doesn't work take out the spark plug and see if it sparks when you pull the cord and make sure it is not fouled. If it is wet with fuel dry out the plug and pull the cord a few times to clear the cylinder. Fresh premium fuel always works best on temperamental engines.
Anonymous
  • 201 Answers
  • Posted on Apr 20, 2010
SOURCE: my pocket bike stops running, and revs by itself
It could be a clog somewhere or he fuel pump. Hope this helps!?
Please rate solution - Thanks.
Anonymous
  • Posted on May 15, 2010
SOURCE: my 49cc pocket bike starts but wont stay on when i
That problem has happened to me to and i just ajusted the needle on the side becuase it was too rich or the breather on the gas tank sometimes that gets fratured and the gas fumes cant get out right
Anonymous
  • Posted on Feb 28, 2011
SOURCE: i tried to fix the pull start on my pocket rocket
Hey Google ur question about the pull start and there's a video that shows u how to do it its real easy.
emissionwiz
Marvin
  • 85242 Answers
  • Posted on Nov 01, 2011
SOURCE: 49 CC STREET SCOOTER TWO STROKE NEED THE GAS TO
the mixture ratio is 50 parts gas to 1 part oil. Use only a good quailty stroke oil, never use motor oil
Trying to start mini quadard 49 cc model atv-2
Try turning the carb set screw all the way in and back out 1 1/4 turns. If you need more... do it in 1/4 turn increments.
Atv wont start has fire gas in cylinder wasrunning fine quite on it own has only 1500kms on bike
you have a carb issue. turn the set screw all the way in and back it out 1 1/4 turns. this should work for you. if you need to adjust it... do it in 1/4 turn increments.
My bike wont start I replaced spark plug
most likely carb setting. Try turning the carb set screw all the way in and back out 1 1/4 of a turn. then adjust by 1/4 of a turn to fine tune it.
49cc atv will not idle just drives
there should be an idler screw on the side of the carb. its has a spring behind it loosen the screw and see if that helps and dont loosen it too much its best to do this with it running
1helpful
Wheres the choke on a 49cc pocket rocket
The choke is on the carb. Check if the carb set screw is set right, turn it all the way in and then back out 1 1/4 turns. then fine tune by 1/4 turn increments.
3helpful
2answers
49 CC STREET SCOOTER TWO STROKE NEED THE GAS TO OIL MIXTURE
2helpful
I tried to fix the pull start on my pocket rocket
3helpful
My 49cc pocket bike starts but wont stay on when i give it gas?
1helpful
2answers
Pocket bike prblems
Top Quad Cycling Experts
ZJ Limited
ZJ Limited
NOEL
NOEL
Kardoc
Are you a Quad Cycling Expert? Answer questions, earn points and help others
