I turn the LCD|TV on and then insert the proper type disc.
I then press the INPUT button and use the down arrow to DVD and press the ENTER button followed by the OK button.
Nothing happens after the OK button is pressed but the screen says loading.
After a long delay The screen states NO DISC even though it is in the slot. I then try to start over and DO NOT press the ENTER button but just hit the OK button
Then I press the GUIDE button but the set- up menu does not come on.
There is a long pause and usually I hear repeated clicking. I then attempt it again without success
Sounds like the disc player went bad. Polaroid has been having trouble with these players for some time. Call polaroid and check to see if this is a warranty issue. I have fixed these for polaroid before and the service call was comped. Easy change out, only takes about 15 minutes. Hope this helps. J
